Introducción
This guide gives a step by step procedure to remove the front housing for internal repairs.
Qué necesitas
There are six screws attaching the back housing to the camera. Remove the screws from the body with a PH000 screw head.
Two 1.5x2.5mm screws on the right side.
Two 1.5x2.5mm screws on the underside.
Two 1.5x2.5mm screw on the left side.
Remove the four 1.5x2.5mm screws in the battery housing using a PH000 screw head.
Casi Terminas!
Conclusión
