Saltar al contenido principal
Nikon Coolpix L330 Back Housing Replacement
Qué necesitas
  1. Nikon Coolpix L330 Back Housing Replacement, Back Housing: paso 1, imagen 1 de 3 Nikon Coolpix L330 Back Housing Replacement, Back Housing: paso 1, imagen 2 de 3 Nikon Coolpix L330 Back Housing Replacement, Back Housing: paso 1, imagen 3 de 3
    • There are six screws attaching the back housing to the camera. Remove the screws from the body with a PH000 screw head.
    • Two 1.5x2.5mm screws on the right side.
    • Two 1.5x2.5mm screws on the underside.
    • Two 1.5x2.5mm screw on the left side.
  2. Nikon Coolpix L330 Back Housing Replacement: paso 2, imagen 1 de 2 Nikon Coolpix L330 Back Housing Replacement: paso 2, imagen 2 de 2
    • After removing the screws, use a metal spudger or plastic opening tool to push the back cover out.
    • The metal spudger can damage the plastic housing, so use caution when applying any pressure to it. Use a plastic opening tool to reduce the risk of damage to the housing.
    • Remove the back housing of the camera by lifting it directly up.
    • The back cover may be slightly tight, therefore more force may be needed to lift it up.
Conclusión
Taibah
Miembro Desde 02/09/16
121 Reputación
1 Guía escrita
Equipo
USF Tampa, Team 2-10, Cagle Spring 2016 Miembro de USF Tampa, Team 2-10, Cagle Spring 2016
USFT-CAGLE-S16S2G10
Miembros de 4
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 12
Todo El Tiempo: 604
