Saltar al contenido principal
Nikon Coolpix L32 LCD Replacement
Qué necesitas
  1. Nikon Coolpix L32 LCD Replacement, Front Panel: paso 1, imagen 1 de 3 Nikon Coolpix L32 LCD Replacement, Front Panel: paso 1, imagen 2 de 3 Nikon Coolpix L32 LCD Replacement, Front Panel: paso 1, imagen 3 de 3
    • Remove the six(3.93mm screws) on the outside of the camera using a Phillips 00 screwdriver.
  2. Nikon Coolpix L32 LCD Replacement: paso 2, imagen 1 de 1
    • Open the battery compartment door and pull the black back face apart from the front red face.
  3. Nikon Coolpix L32 LCD Replacement, LCD: paso 3, imagen 1 de 1
    • Using the spudger, gently pull the LCD screen from the tray holding it.
    • Do not pull the LCD screen far from the camera because there is a ribbon cable connected to it.
  4. Nikon Coolpix L32 LCD Replacement: paso 4, imagen 1 de 1
    • Use the spudger to lift up the small white retaining flap on the motherboard that is connected to the LCD screen's ribbon cable.
  5. Nikon Coolpix L32 LCD Replacement: paso 5, imagen 1 de 1
    • With the small retaining white flap up, remove the LCD screen ribbon cable from the motherboard by sliding it out.
Conclusión
Una persona más ha completado esta guía.
Sherika Jacobs
Miembro Desde 09/15/16
348 Reputación
3 Guías creadas
Equipo
USF Tampa, Team 2-4, Blackwell Fall 2016 Miembro de USF Tampa, Team 2-4, Blackwell Fall 2016
USFT-BLACKWELL-F16S2G4
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 7
Todo El Tiempo: 790
