Saltar al contenido principal
Nikon Coolpix L27 Screen Replacement
Qué necesitas
  1. Nikon Coolpix L27 Screen Replacement, Screen: paso 1, imagen 1 de 3 Nikon Coolpix L27 Screen Replacement, Screen: paso 1, imagen 2 de 3 Nikon Coolpix L27 Screen Replacement, Screen: paso 1, imagen 3 de 3
    • Undo the latch at the bottom of the camera by pushing it to the side
    • Remove the batteries (and memory card if applicable)
  2. Nikon Coolpix L27 Screen Replacement: paso 2, imagen 1 de 2 Nikon Coolpix L27 Screen Replacement: paso 2, imagen 2 de 2
    • Remove the two 5 mm Phillips #000 screws from the left side.
  3. Nikon Coolpix L27 Screen Replacement: paso 3, imagen 1 de 3 Nikon Coolpix L27 Screen Replacement: paso 3, imagen 2 de 3 Nikon Coolpix L27 Screen Replacement: paso 3, imagen 3 de 3
    • Lift the cover labeled "A/V OUT" to expose a hidden screw.
    • Remove two 5 mm Phillips #000 screws from the bottom of the camera.
  4. Nikon Coolpix L27 Screen Replacement: paso 4, imagen 1 de 2 Nikon Coolpix L27 Screen Replacement: paso 4, imagen 2 de 2
    • Remove the two 5 mm Phillips #000 screws from the right side of the camera.
  5. Nikon Coolpix L27 Screen Replacement: paso 5, imagen 1 de 3 Nikon Coolpix L27 Screen Replacement: paso 5, imagen 2 de 3 Nikon Coolpix L27 Screen Replacement: paso 5, imagen 3 de 3
    • Carefully pry the back cover starting from the battery latch.
    • Once all sides are loose, lift the back cover up and off.
  6. Nikon Coolpix L27 Screen Replacement: paso 6, imagen 1 de 1
    • Carefully lift the LCD screen up towards the bottom of the camera.
    • The LCD is connected to a cable so don't pull it out yet.
  7. Nikon Coolpix L27 Screen Replacement: paso 7, imagen 1 de 1
    • Lightly push back the white switch holding in the screen cable
  8. Nikon Coolpix L27 Screen Replacement: paso 8, imagen 1 de 2 Nikon Coolpix L27 Screen Replacement: paso 8, imagen 2 de 2
    • Remove the cable from the camera.
    • Lift the screen out.
Conclusión
Vishalpreet Sandhu
Miembro Desde 01/18/22
157 Reputación
1 Guía escrita
Equipo
2 comentarios
would you know how to replace the little button battery just next to the screen, because the Lense is not retracting anymore?
Walter D. - Contestar
where can i buy a screen replacement please
mo0nflwr - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 12
Ultimos 30 días: 30
Todo El Tiempo: 941
