Saltar al contenido principal
Nikon Coolpix L26 Camera LCD Screen Replacement
Qué necesitas
  1. Nikon Coolpix L26 Camera LCD Screen Replacement, Back Cover: paso 1, imagen 1 de 3 Nikon Coolpix L26 Camera LCD Screen Replacement, Back Cover: paso 1, imagen 2 de 3 Nikon Coolpix L26 Camera LCD Screen Replacement, Back Cover: paso 1, imagen 3 de 3
    • Remove the batteries from the battery compartment by sliding the white battery compartment switch up and then move the panel toward the right.
  2. Nikon Coolpix L26 Camera LCD Screen Replacement: paso 2, imagen 1 de 1
    • Using the Phillips #000 screwdriver, unscrew the two 2mm screws next to the battery compartment on the right side of the camera.
  3. Nikon Coolpix L26 Camera LCD Screen Replacement: paso 3, imagen 1 de 1
    • Unscrew the two 2mm screws on the opposite side.
  4. Nikon Coolpix L26 Camera LCD Screen Replacement: paso 4, imagen 1 de 1
    • Flip over the rubber AV cover at the bottom of the camera. Unscrew the last two 2mm screws on the bottom of the camera.
  5. Nikon Coolpix L26 Camera LCD Screen Replacement: paso 5, imagen 1 de 3 Nikon Coolpix L26 Camera LCD Screen Replacement: paso 5, imagen 2 de 3 Nikon Coolpix L26 Camera LCD Screen Replacement: paso 5, imagen 3 de 3
    • Using your hands, open the camera slightly by using the indentation above the camera compartment.
  6. Nikon Coolpix L26 Camera LCD Screen Replacement: paso 6, imagen 1 de 2 Nikon Coolpix L26 Camera LCD Screen Replacement: paso 6, imagen 2 de 2
    • Wedge the flat end of the spudger in between the front and back cover. Carefully push the spudger downward, which will lift the back cover off the camera.
  7. Nikon Coolpix L26 Camera LCD Screen Replacement: paso 7, imagen 1 de 1
    • Gently pull the cover off the camera.
  8. Nikon Coolpix L26 Camera LCD Screen Replacement, LCD Screen: paso 8, imagen 1 de 3 Nikon Coolpix L26 Camera LCD Screen Replacement, LCD Screen: paso 8, imagen 2 de 3 Nikon Coolpix L26 Camera LCD Screen Replacement, LCD Screen: paso 8, imagen 3 de 3
    • Carefully flip over the LCD screen onto its front. Pull the top of the LCD screen toward you keeping the bottom of it inside the camera.
    • Do not pull on the LCD screen; there is a ribbon of circuitry that is connected to the motherboard.
  9. Nikon Coolpix L26 Camera LCD Screen Replacement: paso 9, imagen 1 de 1
    • Gently hold the LCD screen down, so the ribbon lays flat against the back of the camera.
  10. Nikon Coolpix L26 Camera LCD Screen Replacement: paso 10, imagen 1 de 1
    • Gently wedge the spudger underneath the white latch and lift the latch open.
  11. Nikon Coolpix L26 Camera LCD Screen Replacement: paso 11, imagen 1 de 2 Nikon Coolpix L26 Camera LCD Screen Replacement: paso 11, imagen 2 de 2
    • Use the flat side of the spudger to flip the white switch on the motherboard. You should hear a light click.
  12. Nikon Coolpix L26 Camera LCD Screen Replacement: paso 12, imagen 1 de 1
    • Gently pull the ribbon out of the switch.
Conclusión
3 personas más completaron esta guía.
Sadie
Miembro Desde 02/16/15
427 Reputación
3 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 11
Ultimos 30 días: 39
Todo El Tiempo: 2,336
