Saltar al contenido principal
Nikon Coolpix L26 Camera Back Cover Replacement
Qué necesitas
  1. Nikon Coolpix L26 Camera Back Cover Replacement, Back Cover: paso 1, imagen 1 de 3 Nikon Coolpix L26 Camera Back Cover Replacement, Back Cover: paso 1, imagen 2 de 3 Nikon Coolpix L26 Camera Back Cover Replacement, Back Cover: paso 1, imagen 3 de 3
    • Remove the batteries from the battery compartment by sliding the white battery compartment switch up and then move the panel toward the right.
  2. Nikon Coolpix L26 Camera Back Cover Replacement: paso 2, imagen 1 de 1
    • Using the Phillips #000 screwdriver, unscrew the two 2mm screws next to the battery compartment on the right side of the camera.
  3. Nikon Coolpix L26 Camera Back Cover Replacement: paso 3, imagen 1 de 1
    • Unscrew the two 2mm screws on the opposite side.
  4. Nikon Coolpix L26 Camera Back Cover Replacement: paso 4, imagen 1 de 1
    • Flip over the rubber AV cover at the bottom of the camera. Unscrew the last two 2mm screws on the bottom of the camera.
  5. Nikon Coolpix L26 Camera Back Cover Replacement: paso 5, imagen 1 de 3 Nikon Coolpix L26 Camera Back Cover Replacement: paso 5, imagen 2 de 3 Nikon Coolpix L26 Camera Back Cover Replacement: paso 5, imagen 3 de 3
    • Using your hands, open the camera slightly by using the indentation above the camera compartment.
  6. Nikon Coolpix L26 Camera Back Cover Replacement: paso 6, imagen 1 de 2 Nikon Coolpix L26 Camera Back Cover Replacement: paso 6, imagen 2 de 2
    • Wedge the flat end of the spudger in between the front and back cover. Carefully push the spudger downward, which will lift the back cover off the camera.
  7. Nikon Coolpix L26 Camera Back Cover Replacement: paso 7, imagen 1 de 1
    • Gently pull the cover off the camera.
Conclusión
5 personas más completaron esta guía.
Sadie
Miembro Desde 02/16/15
427 Reputación
3 Guías creadas
Equipo
3 comentarios
my battery compartment will not close. can I buy a new one
brendadawsonitp - Contestar
Thanks. I appreciate the help, but… The pin seems to be the toughest item to remove. You didn’t get that far.
srfrjoe57 - Contestar
This worked for the pin. I’m guessing it pushes through the front of the body behind the screen. I didn’t get that far. It for sure will not pull out of the back. I cut the pin and pulled it out (yes it did damage the plastic). I cut a small nail (brad) the put it through the cover and placed the brad in where the old pin was and placed a bit of super glue on it to hold it in place (don’t get any on the new cover). In a while I will assemble the camera and add more super glue. Yes, the super glue will be visible, but it will take some searching to find it and will look much better that a tie-wrap or tape. I hope that helps.
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 16
Todo El Tiempo: 2,057
