Saltar al contenido principal
Nikon Coolpix L16 LCD screen replacement
Qué necesitas
  1. Nikon Coolpix L16 LCD screen replacement, LCD: paso 1, imagen 1 de 3 Nikon Coolpix L16 LCD screen replacement, LCD: paso 1, imagen 2 de 3 Nikon Coolpix L16 LCD screen replacement, LCD: paso 1, imagen 3 de 3
    • Clearly visible damage to the LCD. It did not even light up.
    • Remove the screw from the right side.
    • Remove the visible screw from the left side.
  2. Nikon Coolpix L16 LCD screen replacement: paso 2, imagen 1 de 3 Nikon Coolpix L16 LCD screen replacement: paso 2, imagen 2 de 3 Nikon Coolpix L16 LCD screen replacement: paso 2, imagen 3 de 3
    • Open the USB A/C cover, there is one more screw that needs to be removed. That is why it is important to always remove all covers...
    • Remove the three screws from the bottom.
    • Start splitting the case from the battery compartment. I used an opening tool, but fingernails will be sufficient as well.
  3. Nikon Coolpix L16 LCD screen replacement: paso 3, imagen 1 de 3 Nikon Coolpix L16 LCD screen replacement: paso 3, imagen 2 de 3 Nikon Coolpix L16 LCD screen replacement: paso 3, imagen 3 de 3
    • After the splitting of the case, the LCD is imediately visible.
    • Lift the LCD out of the frame by using your fingernail or an opening tool. Do not remove it yet, it is still connected.
    • Flip the black clasp up by using fingernails or the opening tool. No big force is required. Remove the old LCD.
  4. Nikon Coolpix L16 LCD screen replacement: paso 4, imagen 1 de 2 Nikon Coolpix L16 LCD screen replacement: paso 4, imagen 2 de 2
    • Here is the new screen, note the blue tab. This is the screen protector, remove it after installation.
    • Reassemble in reverse order. Hopefully your results will be the same as for me.
Conclusión
Una persona más ha completado esta guía.
oldturkey03
Miembro Desde 09/29/10
812,408 Reputación
119 Guías creadas
Equipo
Global Fixers Miembro de Global Fixers
Community
45 Miembros
702 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 15
Ultimos 30 días: 45
Todo El Tiempo: 3,117
