Saltar al contenido principal
Nikon Coolpix E5700 Rear LCD Replacement
Qué necesitas
  1. Nikon Coolpix E5700 Rear LCD Replacement, Battery: paso 1, imagen 1 de 2 Nikon Coolpix E5700 Rear LCD Replacement, Battery: paso 1, imagen 2 de 2
    • Use your finger tip to slide the battery release tab toward the battery symbol on the E5700.
    • Open the battery door.
  2. Nikon Coolpix E5700 Rear LCD Replacement: paso 2, imagen 1 de 1
    • Pull the battery out of the E5700.
    • It may be necessary to wiggle the battery while pulling to free it from its pocket in the case.
  3. Nikon Coolpix E5700 Rear LCD Replacement, Rear LCD: paso 3, imagen 1 de 1
    • Remove two Phillips screws (3.4 mm) located on the left side of the screen.
  4. Nikon Coolpix E5700 Rear LCD Replacement: paso 4, imagen 1 de 2 Nikon Coolpix E5700 Rear LCD Replacement: paso 4, imagen 2 de 2
    • Remove two Phillips screws (3.4 mm) located on the right side of the screens.
  5. Nikon Coolpix E5700 Rear LCD Replacement: paso 5, imagen 1 de 2 Nikon Coolpix E5700 Rear LCD Replacement: paso 5, imagen 2 de 2
    • Remove back plastic monitor cover.
  6. Nikon Coolpix E5700 Rear LCD Replacement: paso 6, imagen 1 de 1
    • Remove the Phillips screw on the top right side of the screen.
  7. Nikon Coolpix E5700 Rear LCD Replacement: paso 7, imagen 1 de 1
    • Carefully unplug the grey bundle of wires in the white housing.
  8. Nikon Coolpix E5700 Rear LCD Replacement: paso 8, imagen 1 de 1
    • Carefully unplug the small pink and wires in the grey housing.
  9. Nikon Coolpix E5700 Rear LCD Replacement: paso 9, imagen 1 de 1
    • Remove the two Phillips screws on the left side of the screen.
  10. Nikon Coolpix E5700 Rear LCD Replacement: paso 10, imagen 1 de 1
    • Remove the metal bar on the left side of the screen.
    • Remove the screen from the front plastic housing.
Conclusión
Una persona más ha completado esta guía.
Kyle Sitton
Miembro Desde 04/17/11
351 Reputación
7 Guías creadas
Equipo
Cal Poly, Team 24-58, Amido Spring 2011 Miembro de Cal Poly, Team 24-58, Amido Spring 2011
CPSU-AMIDO-S11S24G58
4 Miembros
18 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 4
Todo El Tiempo: 2,399
