Saltar al contenido principal
Nikon Coolpix B700 LCD Screen Replacement
Qué necesitas
  1. Nikon Coolpix B700 LCD Screen Replacement, LCD Screen: paso 1, imagen 1 de 2 Nikon Coolpix B700 LCD Screen Replacement, LCD Screen: paso 1, imagen 2 de 2
    • Use a Phillips screwdriver to remove the two 3.5mm screws at the top and bottom of the LCD Screen.
  2. Nikon Coolpix B700 LCD Screen Replacement: paso 2, imagen 1 de 2 Nikon Coolpix B700 LCD Screen Replacement: paso 2, imagen 2 de 2
    • Use a Phillips screwdriver to remove the two 3.5mm screws on both sides of the side of the screen.
  3. Nikon Coolpix B700 LCD Screen Replacement: paso 3, imagen 1 de 1
    • Use to metal spudger to pry open the LCD cover. Then slide it down the length of the screen until the cover comes apart.
  4. Nikon Coolpix B700 LCD Screen Replacement: paso 4, imagen 1 de 1
    • Use the pry tool and slide it under the black tab and lift up gently. Do this again for the other two ZIF tabs.
  5. Nikon Coolpix B700 LCD Screen Replacement: paso 5, imagen 1 de 1
    Herramienta utilizada en este paso:
    Desoldering Pump
    $3.99
    • Use the solder gun and desolder the yellow and blue wires.
  6. Nikon Coolpix B700 LCD Screen Replacement: paso 6, imagen 1 de 1
    • Use the jimmy and slide it in between the LCD screen and lift out the LCD Screen.
Conclusión
2 personas más completaron esta guía.
2Guía Comentarios
Hi, I like the first 6 steps, but what are the rest of the steps?
Kevin Kirkendall - Contestar
My camera the screen go’s when outside and if it cold.
gsb1306 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 35
Todo El Tiempo: 2,595
