Saltar al contenido principal
Nikon Coolpix B700 Back Frame Assembly Replacement
Qué necesitas
  1. Nikon Coolpix B700 Back Frame Assembly Replacement, Back Frame Assembly: paso 1, imagen 1 de 1
    • Use the Phillips screwdriver to remove the two 5.5 mm screws on the left side of the camera.
  2. Nikon Coolpix B700 Back Frame Assembly Replacement: paso 2, imagen 1 de 1
    • Use the Phillips screwdriver to remove seven 5.5 mm screws from the bottom of the camera.
  3. Nikon Coolpix B700 Back Frame Assembly Replacement: paso 3, imagen 1 de 2 Nikon Coolpix B700 Back Frame Assembly Replacement: paso 3, imagen 2 de 2
    • Use the Phillips screwdriver to remove the two 5.5mm screws on the right side of the camera.
    • Open the HDMI flap to remove a 5.5mm screw.
    • Don't forget to replace the hidden screw under the HDMI flap during reassembly.
  4. Nikon Coolpix B700 Back Frame Assembly Replacement: paso 4, imagen 1 de 1
    • Use the Phillips screwdriver to remove the two 5.5mm screws under the LCD panel.
  5. Nikon Coolpix B700 Back Frame Assembly Replacement: paso 5, imagen 1 de 3 Nikon Coolpix B700 Back Frame Assembly Replacement: paso 5, imagen 2 de 3 Nikon Coolpix B700 Back Frame Assembly Replacement: paso 5, imagen 3 de 3
    • Open the flash assembly and insert the spudger into the slot under the flash unit and twist.
    • While twisting, pry apart the shell to split the camera in half.
  6. Nikon Coolpix B700 Back Frame Assembly Replacement: paso 6, imagen 1 de 1
    • Be careful not to damage the ribbons that connect the halves together.
  7. Nikon Coolpix B700 Back Frame Assembly Replacement: paso 7, imagen 1 de 2 Nikon Coolpix B700 Back Frame Assembly Replacement: paso 7, imagen 2 de 2
    • Place the pry tool under the black latch. Lift gently until the latch flips up.
    • Gently pull the ribbon away from the latch.
    • Be gentle when taking ribbons out and apart because they are fragile.
Linea de Meta
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 4
Ultimos 30 días: 23
Todo El Tiempo: 691
