Saltar al contenido principal
Nikon Coolpix AW130 Front Panel Replacement
Qué necesitas
  1. Nikon Coolpix AW130 Front Panel Replacement, Battery: paso 1, imagen 1 de 2 Nikon Coolpix AW130 Front Panel Replacement, Battery: paso 1, imagen 2 de 2
    • Using your thumb and pointer finger, open the card/battery hatch by pressing the center button of the wheel and turning the entire wheel to the left.
    • When reassembling, you must turn this wheel to the right until it clicks.
  2. Nikon Coolpix AW130 Front Panel Replacement: paso 2, imagen 1 de 2 Nikon Coolpix AW130 Front Panel Replacement: paso 2, imagen 2 de 2
    • You should feel the door begin to loosen. Carefully pull the hatch open.
  3. Nikon Coolpix AW130 Front Panel Replacement: paso 3, imagen 1 de 1
    • Push the yellow battery/charger compartment tab up using your thumb nail.
  4. Nikon Coolpix AW130 Front Panel Replacement: paso 4, imagen 1 de 2 Nikon Coolpix AW130 Front Panel Replacement: paso 4, imagen 2 de 2
    • After pressing the yellow tab, the battery should loosen.
    • Slowly pull the battery completely out.
  5. Nikon Coolpix AW130 Front Panel Replacement, Front Panel: paso 5, imagen 1 de 2 Nikon Coolpix AW130 Front Panel Replacement, Front Panel: paso 5, imagen 2 de 2
    • Using the T4 Torx Screwdriver, remove the 2, 4mm screws holding the N-Mark plate in place.
    • Carefully pull the plate off of the face.
  6. Nikon Coolpix AW130 Front Panel Replacement: paso 6, imagen 1 de 2 Nikon Coolpix AW130 Front Panel Replacement: paso 6, imagen 2 de 2
    • Using the metal spudger tool, pry the colored face from the camera body.
    • Avoid bending or scratching the front face.
Conclusión
6 personas más completaron esta guía.
Un comentario
Hello, has this front panel influence on cameras sealing function? Or is it only as shield against mechanical demage?
Slavomir - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 11
Todo El Tiempo: 1,439
