Saltar al contenido principal
Nikon Coolpix A900 Rear Case Replacement
Qué necesitas
  1. Nikon Coolpix A900 Rear Case Replacement, Battery: paso 1, imagen 1 de 1
    • Orient the camera so that it is upside down, with the lens facing towards you.
  2. Nikon Coolpix A900 Rear Case Replacement: paso 2, imagen 1 de 2 Nikon Coolpix A900 Rear Case Replacement: paso 2, imagen 2 de 2
    • Slide the battery door lock left to unlock it.
    • The battery door will automatically open.
  3. Nikon Coolpix A900 Rear Case Replacement: paso 3, imagen 1 de 2 Nikon Coolpix A900 Rear Case Replacement: paso 3, imagen 2 de 2
    • Slide the yellow tab up to release the battery.
    • To re-insert a battery, slide the battery back in until the yellow tab locks it in place.
    • There is a diagram on the opposite side of the battery compartment to help you orient the battery correctly.
  4. Nikon Coolpix A900 Rear Case Replacement, Rear Case: paso 4, imagen 1 de 3 Nikon Coolpix A900 Rear Case Replacement, Rear Case: paso 4, imagen 2 de 3 Nikon Coolpix A900 Rear Case Replacement, Rear Case: paso 4, imagen 3 de 3
    • Orient the camera upside down, with the lens facing away from you.
    • Remove the two 3mm Phillips #00 screws from the right.
    • Remove the two 3.4mm Phillips #00 screws from the left.
  5. Nikon Coolpix A900 Rear Case Replacement: paso 5, imagen 1 de 3 Nikon Coolpix A900 Rear Case Replacement: paso 5, imagen 2 de 3 Nikon Coolpix A900 Rear Case Replacement: paso 5, imagen 3 de 3
    • Turn the camera on its side, with the lens facing away from you.
    • Remove the 3.4mm Phillips #00 screw. Repeat this for the opposite side of the camera.
  6. Nikon Coolpix A900 Rear Case Replacement: paso 6, imagen 1 de 3 Nikon Coolpix A900 Rear Case Replacement: paso 6, imagen 2 de 3 Nikon Coolpix A900 Rear Case Replacement: paso 6, imagen 3 de 3
    • Place the camera upright with the lens facing away from you.
    • Move the monitor down, and remove two 4.4 mm screws.
  7. Nikon Coolpix A900 Rear Case Replacement: paso 7, imagen 1 de 2 Nikon Coolpix A900 Rear Case Replacement: paso 7, imagen 2 de 2
    • Remove the two black 2.5 mm screws from the monitor bracket.
  8. Nikon Coolpix A900 Rear Case Replacement: paso 8, imagen 1 de 2 Nikon Coolpix A900 Rear Case Replacement: paso 8, imagen 2 de 2
    • Return the monitor to the closed position.
    • Gently open the rear case.
    • You may need opening tools to help separate the rear case.
    • Be careful when opening the rear case to not damage the ribbon connectors.
  9. Nikon Coolpix A900 Rear Case Replacement: paso 9, imagen 1 de 3 Nikon Coolpix A900 Rear Case Replacement: paso 9, imagen 2 de 3 Nikon Coolpix A900 Rear Case Replacement: paso 9, imagen 3 de 3
    • Place the camera lens down, while supporting the rear case.
    • Unlock the two ribbons by using your finger to lift the plastic hinge on the ribbon connector.
    • With the ribbons disconnected, you can now remove the rear case.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 8
Todo El Tiempo: 469
