Introducción
This iFixit guide shows you how to disassemble the Nikon Coolpix 995 camera, and remove/replace the LCD display.
Qué necesitas
Turn the lens/flash assembly 90 degrees, until you see the two Phillips #00 screws,
Remove the two screws with a Phillips #00 screwdriver.
Flip the flash so that you can access the remaining two screws. Remove these screws following the same method as before.
Casi Terminas!
Conclusión
