Saltar al contenido principal
Nikon Coolpix 7900 Back Cover Replacement
Qué necesitas
  1. Nikon Coolpix 7900 Back Cover Replacement, Back Cover: paso 1, imagen 1 de 1
    • Remove the four 3.0mm screws on the bottom of the camera.
  2. Nikon Coolpix 7900 Back Cover Replacement: paso 2, imagen 1 de 1
    • Remove the two 3.0mm screws on the left side of the camera near the memory card compartment.
  3. Nikon Coolpix 7900 Back Cover Replacement: paso 3, imagen 1 de 1
    • Remove the two 3.0mm screws on the right side of the camera.
  4. Nikon Coolpix 7900 Back Cover Replacement: paso 4, imagen 1 de 1
    • Carefully open the back cover. Take care as there are connectors still attached.
  5. Nikon Coolpix 7900 Back Cover Replacement: paso 5, imagen 1 de 1
    • Disconnect the cable by pulling the head upward along the green circuit board. If you only are changing the LCD, skip this step.
  6. Nikon Coolpix 7900 Back Cover Replacement: paso 6, imagen 1 de 1
    • Disconnect the ribbon cable by grabbing the two handles and pulling it directly out of the socket. If you are only changing LCD, skip this step.
    • The back cover will be disconnected from the camera
Conclusión
Una persona más ha completado esta guía.
Kaky Payne
Miembro Desde 04/17/12
112 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 12-38, Regan Spring 2012 Miembro de Cal Poly, Team 12-38, Regan Spring 2012
CPSU-REGAN-S12S12G38
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 1,265
