Saltar al contenido principal
Nikon Coolpix 775 Screen Replacement
Qué necesitas
  1. Nikon Coolpix 775 Screen Replacement, Battery: paso 1, imagen 1 de 3 Nikon Coolpix 775 Screen Replacement, Battery: paso 1, imagen 2 de 3 Nikon Coolpix 775 Screen Replacement, Battery: paso 1, imagen 3 de 3
    • Flip the camera, so the bottom is facing up.
  2. Nikon Coolpix 775 Screen Replacement: paso 2, imagen 1 de 2 Nikon Coolpix 775 Screen Replacement: paso 2, imagen 2 de 2
    • Slide the gray latch to the open "pac-man" symbol.
  3. Nikon Coolpix 775 Screen Replacement: paso 3, imagen 1 de 3 Nikon Coolpix 775 Screen Replacement: paso 3, imagen 2 de 3 Nikon Coolpix 775 Screen Replacement: paso 3, imagen 3 de 3
    • Flip up the cover and remove the battery inside the slot.
  4. Nikon Coolpix 775 Screen Replacement, Motherboard: paso 4, imagen 1 de 3 Nikon Coolpix 775 Screen Replacement, Motherboard: paso 4, imagen 2 de 3 Nikon Coolpix 775 Screen Replacement, Motherboard: paso 4, imagen 3 de 3
    • Unscrew the eight 4mm long JIS #00 screws from the bottom, right side, and the left side.
  5. Nikon Coolpix 775 Screen Replacement: paso 5, imagen 1 de 3 Nikon Coolpix 775 Screen Replacement: paso 5, imagen 2 de 3 Nikon Coolpix 775 Screen Replacement: paso 5, imagen 3 de 3
    • Grab the camera with both your hand from the front and the back.
    • Pull the two parts apart.
    • You may have to pull at different angles to get the two parts to separate, but make sure you don't pull too hard because there is a wire connection on the inside.
  6. Nikon Coolpix 775 Screen Replacement: paso 6, imagen 1 de 3 Nikon Coolpix 775 Screen Replacement: paso 6, imagen 2 de 3 Nikon Coolpix 775 Screen Replacement: paso 6, imagen 3 de 3
    Herramienta utilizada en este paso:
    • Flip the camera back so you can see the top.
    • Pull the ribbon cable out of the socket connecting to the motherboard by using your hands or tweezers.
    • Be careful not to puncture or rip the ribbon cable.
  7. Nikon Coolpix 775 Screen Replacement: paso 7, imagen 1 de 3 Nikon Coolpix 775 Screen Replacement: paso 7, imagen 2 de 3 Nikon Coolpix 775 Screen Replacement: paso 7, imagen 3 de 3
    • Look back to the top of the camera.
    • Flip up the tab that is exposed right by the dial using tweezers.
    • Release the ribbon to be able to separate the top part of the back of the camera.
    • Be careful not to rip the ribbon cable.
  8. Nikon Coolpix 775 Screen Replacement: paso 8, imagen 1 de 3 Nikon Coolpix 775 Screen Replacement: paso 8, imagen 2 de 3 Nikon Coolpix 775 Screen Replacement: paso 8, imagen 3 de 3
    • Look at the top side of the camera.
    • Unscrew the two 4mm Phillips #00 screws.
    • Unscrew the 2mm JIS #00 screw as well.
  9. Nikon Coolpix 775 Screen Replacement: paso 9, imagen 1 de 3 Nikon Coolpix 775 Screen Replacement: paso 9, imagen 2 de 3 Nikon Coolpix 775 Screen Replacement: paso 9, imagen 3 de 3
    • Push or slide the the top dial toward the backside of the camera to unclip from the motherboard.
  10. Nikon Coolpix 775 Screen Replacement: paso 10, imagen 1 de 2 Nikon Coolpix 775 Screen Replacement: paso 10, imagen 2 de 2
    • Pull the red and black wire out of the socket on the motherboard.
    • Pull motherboard up out of camera.
  11. Nikon Coolpix 775 Screen Replacement: paso 11, imagen 1 de 3 Nikon Coolpix 775 Screen Replacement: paso 11, imagen 2 de 3 Nikon Coolpix 775 Screen Replacement: paso 11, imagen 3 de 3
    • Pull the ribbon connected to the dial off the motherboard.
  12. Nikon Coolpix 775 Screen Replacement, Screen: paso 12, imagen 1 de 2 Nikon Coolpix 775 Screen Replacement, Screen: paso 12, imagen 2 de 2
    • Remove the orange ribbon cable from its connector by firmly but gently pulling it.
  13. Nikon Coolpix 775 Screen Replacement: paso 13, imagen 1 de 2 Nikon Coolpix 775 Screen Replacement: paso 13, imagen 2 de 2
    • Pull out the pink cable connector.
    • If it's not coming loose, use a pair of needle nose pliers to get a good grip on the connector.
  14. Nikon Coolpix 775 Screen Replacement: paso 14, imagen 1 de 3 Nikon Coolpix 775 Screen Replacement: paso 14, imagen 2 de 3 Nikon Coolpix 775 Screen Replacement: paso 14, imagen 3 de 3
    • Grab the back of the screen and gently lift up.
    • It is only held on by adhesive so it should come out relatively easy.
Conclusión
Nick Meador
Miembro Desde 11/05/18
97 Reputación
1 Guía escrita
Equipo
IUPUI, Team S2-G3, Baechle Fall 2018 Miembro de IUPUI, Team S2-G3, Baechle Fall 2018
IUPUI-BAECHLE-F18S2G3
Miembros de 3
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 6
Todo El Tiempo: 259
