Saltar al contenido principal
Nikon Coolpix 5400 Battery Replacement
Qué necesitas
  1. Nikon Coolpix 5400 Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Turn the camera so that the base is oriented facing up and the front of the camera is facing towards you.
  2. Nikon Coolpix 5400 Battery Replacement: paso 2, imagen 1 de 2 Nikon Coolpix 5400 Battery Replacement: paso 2, imagen 2 de 2
    • Push the battery compartment door latch, located on the right-hand side of the camera, away from you to release the catch.
    • Release the latch and pull your hand away. The spring inside the compartment will push both the battery up and the door open.
    • Push the battery door the rest of the way open to fully expose the battery.
  3. Nikon Coolpix 5400 Battery Replacement: paso 3, imagen 1 de 1
    • Grasp the battery with your thumb and forefinger and pull up and out of the camera housing.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 5
Todo El Tiempo: 394
