Saltar al contenido principal
Nikon Coolpix 5400 Back Cover Replacement
Qué necesitas
  1. Nikon Coolpix 5400 Back Cover Replacement, Back Cover: paso 1, imagen 1 de 1
    • Remove one 3.0mm Phillips #0 screw from the top of the case.
  2. Nikon Coolpix 5400 Back Cover Replacement: paso 2, imagen 1 de 1
    • Remove two 3.0mm Phillips #0 screws from the card reader side of the case.
  3. Nikon Coolpix 5400 Back Cover Replacement: paso 3, imagen 1 de 1
    • Remove four 3.0mm Phillips #0 screws from the bottom of the camera.
  4. Nikon Coolpix 5400 Back Cover Replacement: paso 4, imagen 1 de 1
    • Remove one 3.0mm Phillips #0 screw from the side of the camera.
  5. Nikon Coolpix 5400 Back Cover Replacement: paso 5, imagen 1 de 1
    • Use a plastic opening tool to gently remove the back case from the rest of the camera.
  6. Nikon Coolpix 5400 Back Cover Replacement: paso 6, imagen 1 de 1
    • Pull the back of the camera cover apart.
    • Connecting wires that are still attached to the back cover are fragile.
  7. Nikon Coolpix 5400 Back Cover Replacement: paso 7, imagen 1 de 2 Nikon Coolpix 5400 Back Cover Replacement: paso 7, imagen 2 de 2
    • Remove the two 4.0mm Phillips #0 screws holding the circuit board to the back case.
  8. Nikon Coolpix 5400 Back Cover Replacement: paso 8, imagen 1 de 1
    • Pull the LCD screen cables in the direction that the wires are exiting the circuit board.
    • Pull the wire connector gently, the plastic is very fragile.
  9. Nikon Coolpix 5400 Back Cover Replacement: paso 9, imagen 1 de 2 Nikon Coolpix 5400 Back Cover Replacement: paso 9, imagen 2 de 2
    • Pull the toggle wheel wire connector up and away from the top of the camera.
    • Pull the button control panel wire connector up and away from the top of the camera.
    • Gently remove the wire connectors; the plastic is fragile.
  10. Nikon Coolpix 5400 Back Cover Replacement: paso 10, imagen 1 de 1
    • Remove the six 3.0mm Phillips #0 screws holding the button control panel.
    • Remove the back cover from the camera body.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 16
Todo El Tiempo: 383
