Saltar al contenido principal
Introducción
Replacing the logic board of a Nikon Coolpix 3500
Partes
No se especificaron partes.
  1. Nikon Coolpix 3500 Logic Board Replacement, Battery: paso 1, imagen 1 de 1
    • Unlatch the battery cover. Slide the cover out and flip it open.
    • Remove the battery.
    • Gently remove the battery cover.
  2. Nikon Coolpix 3500 Logic Board Replacement, Front Cover: paso 2, imagen 1 de 1
    • Remove the two 4.5 mm screws that sit next to the battery slot.
    • Remove the 3 mm screw that sits below the CF card slot.
    • Remove the 4.5 mm screw that sits above the digital I/O cover.
  3. Nikon Coolpix 3500 Logic Board Replacement: paso 3, imagen 1 de 1
    • Remove the two 4.5 mm screws that sit inside the battery slot.
  4. Nikon Coolpix 3500 Logic Board Replacement: paso 4, imagen 1 de 1
    • Remove the two 5 mm screws that sit near the camera strap eyelet.
    • Remove the camera strap eyelet.
  5. Nikon Coolpix 3500 Logic Board Replacement: paso 5, imagen 1 de 1
    • Remove the 5 mm screw and cap that were underneath the camera strap eyelet.
  6. Nikon Coolpix 3500 Logic Board Replacement: paso 6, imagen 1 de 2 Nikon Coolpix 3500 Logic Board Replacement: paso 6, imagen 2 de 2
    • Remove the five 3.5 mm screws that sit at the bottom of the camera.
    • Remove the grey plastic piece, which the five screws held in place, by gently detaching the front cover.
    • Do not apply too much force; two wires still connect the front cover to the motherboard.
  7. Nikon Coolpix 3500 Logic Board Replacement: paso 7, imagen 1 de 2 Nikon Coolpix 3500 Logic Board Replacement: paso 7, imagen 2 de 2
    • Using a spudger, detach the white-capped wire.
    • Using a spudger, detach the orange-capped wire and set the front cover aside.
  8. Nikon Coolpix 3500 Logic Board Replacement, Logic Board: paso 8, imagen 1 de 1
    • Detach the grey-capped wire.
    • Detach the green chip that sits next to the blue wires.
  9. Nikon Coolpix 3500 Logic Board Replacement: paso 9, imagen 1 de 2 Nikon Coolpix 3500 Logic Board Replacement: paso 9, imagen 2 de 2
    • Remove the 3.5 mm screw that sits next to the rotating lens.
    • Invert the logic board and lens to uncover the orange and blue ribbon cables. These cables still connect the logic board to the LCD screen.
  10. Nikon Coolpix 3500 Logic Board Replacement: paso 10, imagen 1 de 2 Nikon Coolpix 3500 Logic Board Replacement: paso 10, imagen 2 de 2
    • Detach the blue ribbon cable.
    • Detach the orange ribbon cable by using a spudger, and while pushing it out horizontally.
    • Detach the red-capped wire.
    • Lift the logic board and lens, which are still connected, out of the back cover.
  11. Nikon Coolpix 3500 Logic Board Replacement: paso 11, imagen 1 de 1
    • Lift the black covering and remove the orange ribbon cable, which connects the lens to the logic board.
Conclusión
Equipo
Cal Poly, Team 30-38, Garner Spring 2010 Miembro de Cal Poly, Team 30-38, Garner Spring 2010
CPSU-GARNER-S10S30G38
5 Miembros
11 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 1,973
