Saltar al contenido principal
Nikon CoolPix S600 LCD Replacement
Qué necesitas
  1. Nikon CoolPix S600 LCD Replacement, Front and Rear Casing: paso 1, imagen 1 de 1
    • With the lens facing forward, remove the one 4.2 mm screw on the bottom right hand corner of the camera.
  2. Nikon CoolPix S600 LCD Replacement: paso 2, imagen 1 de 1
    • Remove the chrome side cover from the body of the camera.
  3. Nikon CoolPix S600 LCD Replacement: paso 3, imagen 1 de 1
    • Remove the four 3.2 mm screws on the bottom of the camera.
  4. Nikon CoolPix S600 LCD Replacement: paso 4, imagen 1 de 2 Nikon CoolPix S600 LCD Replacement: paso 4, imagen 2 de 2
    • Remove the two 3.2 mm screws from the right side of the camera (with lens is facing forward)
    • Remove the one 3.2 mm screw from the left side of the camera (with lens facing foward)
  5. Nikon CoolPix S600 LCD Replacement: paso 5, imagen 1 de 2 Nikon CoolPix S600 LCD Replacement: paso 5, imagen 2 de 2
    • Gently separate the back cover from the body of the camera.
    • The back casing will still be connected to the circuit board by a ribbon
  6. Nikon CoolPix S600 LCD Replacement: paso 6, imagen 1 de 1
    • Use the tweezers to disconnect the ribbon from the circuit board.
  7. Nikon CoolPix S600 LCD Replacement: paso 7, imagen 1 de 1
    • Remove the one 2.6 mm screw from the left side of the camera (with the lens facing forward)
  8. Nikon CoolPix S600 LCD Replacement: paso 8, imagen 1 de 2 Nikon CoolPix S600 LCD Replacement: paso 8, imagen 2 de 2
    • Gently separate the front cover from the body of the camera.
    • The front casing will still be connected to the circuit board by a few wires
  9. Nikon CoolPix S600 LCD Replacement: paso 9, imagen 1 de 1
    • Remove the two 3.2 mm screws that hold the flash to the front cover.
  10. Nikon CoolPix S600 LCD Replacement: paso 10, imagen 1 de 3 Nikon CoolPix S600 LCD Replacement: paso 10, imagen 2 de 3 Nikon CoolPix S600 LCD Replacement: paso 10, imagen 3 de 3
    • Use the Spudger to remove the copper colored light bulb clip.
    • Remove the front cover entierly from the camera body.
  11. Nikon CoolPix S600 LCD Replacement, LCD: paso 11, imagen 1 de 1
    • Gently remove LCD ribbon from the mother board
    • The screen will still be connected to the mother board by two very small wires (black & red)
  12. Nikon CoolPix S600 LCD Replacement: paso 12, imagen 1 de 1
    • Desolder both wires from the mother board.
    • Refer to iFixit's solder/desoldering guide for the correct procedure to desolder the connection.
  13. Nikon CoolPix S600 LCD Replacement: paso 13, imagen 1 de 1
    • Separate the LCD screen from the rest of the mother board
Conclusión
Equipo
Cuesta, Team 1-6, Zipperian Fall 2011 Miembro de Cuesta, Team 1-6, Zipperian Fall 2011
CUESTA-ZIPPERIAN-F11S1G6
2 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 5
Todo El Tiempo: 1,313
