Saltar al contenido principal
Nikon CoolPix S5 Wrist Strap Holder Replacement
Qué necesitas
  1. Nikon CoolPix S5 Wrist Strap Holder Replacement, Wrist Strap Holder: paso 1, imagen 1 de 1
    • Remove the wrist strap from the wrist strap holder by untying the string at the end of the wrist strap.
    • This will allow for the wrist strap to be pulled through the wrist strap holder.
  2. Nikon CoolPix S5 Wrist Strap Holder Replacement: paso 2, imagen 1 de 1
    • Using the thumb, firmly push the Battery/SD cover in the middle and in the direction of the arrow on the Battery/SD cover.
    • This will cause the Battery/SD cover to pop open.
  3. Nikon CoolPix S5 Wrist Strap Holder Replacement: paso 3, imagen 1 de 1
    • Use the Phillips screwdriver to remove the four screws on the bottom of the camera.
  4. Nikon CoolPix S5 Wrist Strap Holder Replacement: paso 4, imagen 1 de 1
    • Using fingers, pull the silver side panels from each side.
  5. Nikon CoolPix S5 Wrist Strap Holder Replacement: paso 5, imagen 1 de 1
    • On the right hand side of the camera, remove the two screws from the wrist strap handle by using the Phillips screwdriver.
Conclusión
2 personas más completaron esta guía.
Equipo
Clemson, Team 12-5, Benson Spring 2013 Miembro de Clemson, Team 12-5, Benson Spring 2013
CLEM-BENSON-S13S12G5
4 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 20
Ultimos 30 días: 24
Todo El Tiempo: 604
