Saltar al contenido principal
Nikon CoolPix S5 Plastic LCD Screen Cover Replacement
Qué necesitas
  1. Nikon CoolPix S5 Plastic LCD Screen Cover Replacement, Back Cover: paso 1, imagen 1 de 1
    • Remove the wristlet by untying the strap.
  2. Nikon CoolPix S5 Plastic LCD Screen Cover Replacement: paso 2, imagen 1 de 1
    • Open the SD/Battery cover.
  3. Nikon CoolPix S5 Plastic LCD Screen Cover Replacement: paso 3, imagen 1 de 2 Nikon CoolPix S5 Plastic LCD Screen Cover Replacement: paso 3, imagen 2 de 2
    • Remove the four screws adjacent to the SD/battery opening using a Phillips #00 screwdriver.
  4. Nikon CoolPix S5 Plastic LCD Screen Cover Replacement: paso 4, imagen 1 de 2 Nikon CoolPix S5 Plastic LCD Screen Cover Replacement: paso 4, imagen 2 de 2
    • Remove the side paneling of the camera by prying it off with your hands.
  5. Nikon CoolPix S5 Plastic LCD Screen Cover Replacement: paso 5, imagen 1 de 2 Nikon CoolPix S5 Plastic LCD Screen Cover Replacement: paso 5, imagen 2 de 2
    • Start on the wristlet side of the camera and use the #00 Phillips screwdriver to remove the two screws that hold the backplate in place.
    • Repeat the removal of the two screws on the other side of the camera.
  6. Nikon CoolPix S5 Plastic LCD Screen Cover Replacement: paso 6, imagen 1 de 2 Nikon CoolPix S5 Plastic LCD Screen Cover Replacement: paso 6, imagen 2 de 2
    • Separate the back faceplate from the rest of the camera.
  7. Nikon CoolPix S5 Plastic LCD Screen Cover Replacement, Plastic LCD Screen Cover: paso 7, imagen 1 de 2 Nikon CoolPix S5 Plastic LCD Screen Cover Replacement, Plastic LCD Screen Cover: paso 7, imagen 2 de 2
    • Press lightly on the outer surface of the plastic LCD screen cover in each corner.
    • The plastic LCD screen cover should pop out of the back plate.
Conclusión
2 personas más completaron esta guía.
Josh Miller
Miembro Desde 03/11/13
87 Reputación
3 Guías creadas
Equipo
Clemson, Team 12-5, Benson Spring 2013 Miembro de Clemson, Team 12-5, Benson Spring 2013
CLEM-BENSON-S13S12G5
Miembros de 4
14 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 27
Todo El Tiempo: 465
