Saltar al contenido principal
Nikon CoolPix S5 Battery Replacement
Qué necesitas
  1. Nikon CoolPix S5 Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Using the thumb, firmly push the SD/Battery cover in the middle and then in the direction of the arrow on the SD/Battery cover.
    • This will cause the SD/Battery cover to pop open.
  2. Nikon CoolPix S5 Battery Replacement: paso 2, imagen 1 de 1
    • Press orange clip to eject battery (battery not shown).
  3. Nikon CoolPix S5 Battery Replacement: paso 3, imagen 1 de 1
    • While cupping hand under the bottom of the SD/Battery slot, turn the camera upright.
    • This will cause the battery to fall into the hand (battery not shown).
  4. Nikon CoolPix S5 Battery Replacement: paso 4, imagen 1 de 1
    • Following the positive and negative placement signs, slide the new battery into the battery slot (battery not shown).
  5. Nikon CoolPix S5 Battery Replacement: paso 5, imagen 1 de 1
    • Slide the SD/Battery cover in the reverse direction of the arrow on the SD/Battery cover until it clicks into place.
Conclusión
4 personas más completaron esta guía.
Equipo
Clemson, Team 12-5, Benson Spring 2013 Miembro de Clemson, Team 12-5, Benson Spring 2013
CLEM-BENSON-S13S12G5
4 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 22
Ultimos 30 días: 29
Todo El Tiempo: 786
