Introducción
Something is wrong with the Navigation Panel? Try replacing it.
Qué necesitas
Remove the three 4 mm screws from the bottom of the camera using a #00 Phillips screwdriver.
Remove the single 3.5 mm screw from the bottom of the camera using a #00 Phillips screwdriver.
Slide the yellow navigation panel to the right so that it can be lifted up.
Detach the ribbon cable connecting the navigation panel to the camera.
The navigation panel can now be removed.
