Saltar al contenido principal
Nikon COOLPIX S9500 Navigation Panel Replacement
Qué necesitas
  1. Nikon COOLPIX S9500 Navigation Panel Replacement, Removing Screws: paso 1, imagen 1 de 1
    • Remove the three 4 mm screws from the bottom of the camera using a #00 Phillips screwdriver.
    • Remove the single 3.5 mm screw from the bottom of the camera using a #00 Phillips screwdriver.
  2. Nikon COOLPIX S9500 Navigation Panel Replacement: paso 2, imagen 1 de 2 Nikon COOLPIX S9500 Navigation Panel Replacement: paso 2, imagen 2 de 2
    • With the bottom of the camera facing you, slide the latch on the compartment to the left.
    • Swing the battery compartment door open.
    • Remove the 3.5 mm screw from the inside with a #00 Phillips screwdriver.
  3. Nikon COOLPIX S9500 Navigation Panel Replacement: paso 3, imagen 1 de 1
    • With the screen facing you, locate the two 3.5 mm screws on the left face of the camera. Remove them using a #00 Phillips screwdriver.
  4. Nikon COOLPIX S9500 Navigation Panel Replacement: paso 4, imagen 1 de 1
    • With the screen facing you, locate the three 3.5 mm screws on the right face of the camera. Remove them with a #00 Phillips screwdriver.
    • Two of the screws are located under the port tabs.
  5. Nikon COOLPIX S9500 Navigation Panel Replacement: paso 5, imagen 1 de 2 Nikon COOLPIX S9500 Navigation Panel Replacement: paso 5, imagen 2 de 2
    • Locate the crease where the case comes together.
    • Using a plastic prying tool, pry at the line to remove the camera case.
    • It may take several attempts to remove the case. Remember to pry at all the crease locations on the camera, and not just one spot.
  6. Nikon COOLPIX S9500 Navigation Panel Replacement, Navigation Panel Removal: paso 6, imagen 1 de 3 Nikon COOLPIX S9500 Navigation Panel Replacement, Navigation Panel Removal: paso 6, imagen 2 de 3 Nikon COOLPIX S9500 Navigation Panel Replacement, Navigation Panel Removal: paso 6, imagen 3 de 3
    • Slide the yellow navigation panel to the right so that it can be lifted up.
    • It may take a little pressure to get the panel to separate.
    • Be careful not to damage the ribbon cable that is still attached to the camera.
  7. Nikon COOLPIX S9500 Navigation Panel Replacement: paso 7, imagen 1 de 1
    • Remove the three 4 mm screws with a #00 Phillips screwdriver.
  8. Nikon COOLPIX S9500 Navigation Panel Replacement: paso 8, imagen 1 de 1
    • Locate the magnet and copper tape on the left side of the camera.
    • Gently pull the copper tape off of the metal plate.
    • The copper tape is attached with some glue, so a little force will be needed to detach it.
  9. Nikon COOLPIX S9500 Navigation Panel Replacement: paso 9, imagen 1 de 3 Nikon COOLPIX S9500 Navigation Panel Replacement: paso 9, imagen 2 de 3 Nikon COOLPIX S9500 Navigation Panel Replacement: paso 9, imagen 3 de 3
    • Lift the screen up and swing it to the right, exposing the circuit board underneath.
    • The navigation panel should still be attached to the circuit board with a ribbon cable as indicated in red.
    • Detach the ribbon cable that is connecting the LCD screen and the circuit board.
  10. Nikon COOLPIX S9500 Navigation Panel Replacement, Navigation Panel: paso 10, imagen 1 de 1
    • Detach the ribbon cable connecting the navigation panel to the camera.
    • The navigation panel can now be removed.
Conclusión
Jim Bui
Miembro Desde 01/20/15
817 Reputación
6 Guías creadas
Equipo
USF Tampa, Team 1-4, Blackwell Winter 2015 Miembro de USF Tampa, Team 1-4, Blackwell Winter 2015
USFT-BLACKWELL-W15S1G4
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 17
Todo El Tiempo: 1,031
