Introducción
If the screen does not power on, even when the camera itself is powered on, the LCD screen could be broken. This guide will show the proper instructions for replacing the screen.
Qué necesitas
Remove the three 4 mm screws from the bottom of the camera using a #00 Phillips screwdriver.
Remove the single 3.5 mm screw from the bottom of the camera using a #00 Phillips screwdriver.
Slide the yellow navigation panel to the right so that it can be lifted up.
3 personas más completaron esta guía.
Un comentario
In step 9, you should mention the small circuit board that has to be released from the screen on the top right of the screen. (It can been seen in the step 6 picture.) It would also been helpful if you mentioned the flange on the ribbon cable connector that should be loosened to allow the cable to be disconnected. The guide allowed me to disassemble and reassemble the unit with a new screen, but the camera was totally inoperative afterwards (would not turn on or charge at all) so I can’t say the guide was helpful.
