Saltar al contenido principal
Nikon COOLPIX S610c Rear Casing Replacement
Qué necesitas
  1. Nikon COOLPIX S610c Rear Casing Replacement, Battery: paso 1, imagen 1 de 1
    • On the bottom right of the camera, locate the battery flap switch.
  2. Nikon COOLPIX S610c Rear Casing Replacement: paso 2, imagen 1 de 1
    • Move this switch to the right so the battery flap can flip open.
  3. Nikon COOLPIX S610c Rear Casing Replacement: paso 3, imagen 1 de 1
    • Slide the orange switch to the right as shown. Now the battery can be pulled out. Reverse these steps to re-install.
  4. Nikon COOLPIX S610c Rear Casing Replacement, Rear Casing: paso 4, imagen 1 de 1
    • Remove the three 3x3mm screws attached to the rear casing.
  5. Nikon COOLPIX S610c Rear Casing Replacement: paso 5, imagen 1 de 1
    • The panel can be identified by the wifi logo on its upper half on the camera's side.
    • Remove the 5x3mm screw holding down the panel on the side closest to the lens.
  6. Nikon COOLPIX S610c Rear Casing Replacement: paso 6, imagen 1 de 1
    • Pry the panel off from the bottom using your fingernail.
  7. Nikon COOLPIX S610c Rear Casing Replacement: paso 7, imagen 1 de 1
    • Remove the 3x2mm screw underneath the panel near the top of the camera.
  8. Nikon COOLPIX S610c Rear Casing Replacement: paso 8, imagen 1 de 2 Nikon COOLPIX S610c Rear Casing Replacement: paso 8, imagen 2 de 2
    • Remove the 4x3mm on the opposite side near the selector wheel.
    • Remove the 2x2mm and 3x2mm screws underneath the a/v flap.
  9. Nikon COOLPIX S610c Rear Casing Replacement: paso 9, imagen 1 de 2 Nikon COOLPIX S610c Rear Casing Replacement: paso 9, imagen 2 de 2
    • Pry the back panel away from the body of the camera, using the space you just opened up.
    • Be careful not to damage the ribbon cable on the opposite end of the camera.
    • A small piece of the frame of the camera may fall off, but it can be easily put back into place during reassembly.
  10. Nikon COOLPIX S610c Rear Casing Replacement: paso 10, imagen 1 de 2 Nikon COOLPIX S610c Rear Casing Replacement: paso 10, imagen 2 de 2
    • Pry up the plastic ribbon connectors on the body of the camera to release the ribbon cables.
    • The center connector is detached by flipping the black latch up and away from the center of the camera.
    • The smaller connector is detached by flipping the tan latch up and away from the edge of the camera.
Conclusión
Una persona más ha completado esta guía.
Kevin Backers
Miembro Desde 01/26/12
301 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 9-5, Regan Winter 2012 Miembro de Cal Poly, Team 9-5, Regan Winter 2012
CPSU-REGAN-W12S9G5
Miembros de 5
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 912
