Saltar al contenido principal
Nikon COOLPIX S610c Front Casing Replacement
Qué necesitas
  1. Nikon COOLPIX S610c Front Casing Replacement, Battery: paso 1, imagen 1 de 1
    • On the bottom right of the camera, locate the battery flap switch.
  2. Nikon COOLPIX S610c Front Casing Replacement: paso 2, imagen 1 de 1
    • Move this switch to the right so the battery flap can flip open.
  3. Nikon COOLPIX S610c Front Casing Replacement: paso 3, imagen 1 de 1
    • Slide the orange switch to the right as shown. Now the battery can be pulled out. Reverse these steps to re-install.
  4. Nikon COOLPIX S610c Front Casing Replacement, Rear Casing: paso 4, imagen 1 de 1
    • Remove the three 3x3mm screws attached to the rear casing.
  5. Nikon COOLPIX S610c Front Casing Replacement: paso 5, imagen 1 de 1
    • The panel can be identified by the wifi logo on its upper half on the camera's side.
    • Remove the 5x3mm screw holding down the panel on the side closest to the lens.
  6. Nikon COOLPIX S610c Front Casing Replacement: paso 6, imagen 1 de 1
    • Pry the panel off from the bottom using your fingernail.
  7. Nikon COOLPIX S610c Front Casing Replacement: paso 7, imagen 1 de 1
    • Remove the 3x2mm screw underneath the panel near the top of the camera.
  8. Nikon COOLPIX S610c Front Casing Replacement: paso 8, imagen 1 de 2 Nikon COOLPIX S610c Front Casing Replacement: paso 8, imagen 2 de 2
    • Remove the 4x3mm on the opposite side near the selector wheel.
    • Remove the 2x2mm and 3x2mm screws underneath the a/v flap.
  9. Nikon COOLPIX S610c Front Casing Replacement: paso 9, imagen 1 de 2 Nikon COOLPIX S610c Front Casing Replacement: paso 9, imagen 2 de 2
    • Pry the back panel away from the body of the camera, using the space you just opened up.
    • Be careful not to damage the ribbon cable on the opposite end of the camera.
    • A small piece of the frame of the camera may fall off, but it can be easily put back into place during reassembly.
  10. Nikon COOLPIX S610c Front Casing Replacement: paso 10, imagen 1 de 2 Nikon COOLPIX S610c Front Casing Replacement: paso 10, imagen 2 de 2
    • Pry up the plastic ribbon connectors on the body of the camera to release the ribbon cables.
    • The center connector is detached by flipping the black latch up and away from the center of the camera.
    • The smaller connector is detached by flipping the tan latch up and away from the edge of the camera.
  11. Nikon COOLPIX S610c Front Casing Replacement, Front Casing: paso 11, imagen 1 de 1
    • Remove the three 3x3mm screws that attach the front casing to the bottom.
  12. Nikon COOLPIX S610c Front Casing Replacement: paso 12, imagen 1 de 1
    • Remove the two 3x2 screws and two 3.5x2.5 screws attaching the rear panel to the motherboard.
  13. Nikon COOLPIX S610c Front Casing Replacement: paso 13, imagen 1 de 2 Nikon COOLPIX S610c Front Casing Replacement: paso 13, imagen 2 de 2
    • Lift the back panel off the motherboard.
    • Be careful not to damage the ribbon cable that attaches the mother board to the rear panel.
  14. Nikon COOLPIX S610c Front Casing Replacement: paso 14, imagen 1 de 2 Nikon COOLPIX S610c Front Casing Replacement: paso 14, imagen 2 de 2
    • Detach the ribbon cable from the motherboard by flipping up the latch on the ribbon connector.
    • Note that the white ribbon connector latch flips away from the ribbon cable.
  15. Nikon COOLPIX S610c Front Casing Replacement: paso 15, imagen 1 de 2 Nikon COOLPIX S610c Front Casing Replacement: paso 15, imagen 2 de 2
    • Remove the final 4x3mm screw at the top of the camera near the lens.
  16. Nikon COOLPIX S610c Front Casing Replacement: paso 16, imagen 1 de 2 Nikon COOLPIX S610c Front Casing Replacement: paso 16, imagen 2 de 2
    • Pry the front casing away from the body of the camera.
    • Be careful not to damage the wires that attach the front panel to the motherboard.
    • Short the leads on the capacitor near the flash to avoid a nasty shock when separating the casing from the body.
  17. Nikon COOLPIX S610c Front Casing Replacement: paso 17, imagen 1 de 1
    • Unscrew the three 3x2mm screws that attach the cables to the front casing.
Conclusión
Bryan Bell
Miembro Desde 01/26/12
28 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 9-5, Regan Winter 2012 Miembro de Cal Poly, Team 9-5, Regan Winter 2012
CPSU-REGAN-W12S9G5
5 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 14
Todo El Tiempo: 1,144
