Saltar al contenido principal
Nikon COOLPIX P7700 Focusing Screen Replacement
Qué necesitas
  1. Nikon COOLPIX P7700 Focusing Screen Replacement, Back Casing: paso 1, imagen 1 de 2 Nikon COOLPIX P7700 Focusing Screen Replacement, Back Casing: paso 1, imagen 2 de 2
    • Turn camera to the left side and remove the two 4.3 mm black side screws using the Phillips #00 screwdriver.
    • Remove the side panel.
  2. Nikon COOLPIX P7700 Focusing Screen Replacement: paso 2, imagen 1 de 1
    • Open the touch screen, and remove the three 4.3 mm black screws inside using the Phillips #00 screwdriver.
  3. Nikon COOLPIX P7700 Focusing Screen Replacement: paso 3, imagen 1 de 1
    • Remove the 4.3 mm black screw on top of the camera, right above where the screen folds out. Use the Phillips #00 screwdriver.
  4. Nikon COOLPIX P7700 Focusing Screen Replacement: paso 4, imagen 1 de 1
    • Remove the two 4.3 mm black screws on the right side of the camera using the Phillips #00 screwdriver.
  5. Nikon COOLPIX P7700 Focusing Screen Replacement: paso 5, imagen 1 de 1
    • Remove the 4.3 mm black screws on the bottom of the camera using the Phillips #00 screwdriver.
  6. Nikon COOLPIX P7700 Focusing Screen Replacement: paso 6, imagen 1 de 2 Nikon COOLPIX P7700 Focusing Screen Replacement: paso 6, imagen 2 de 2
    • Begin separating the camera into two parts.
    • It is okay to remove the orange ribbon. This will be easily put back into place when re-assembling.
  7. Nikon COOLPIX P7700 Focusing Screen Replacement: paso 7, imagen 1 de 1
    • Remove the back casing.
  8. Nikon COOLPIX P7700 Focusing Screen Replacement, Focusing Screen: paso 8, imagen 1 de 1
    • Once the back casing is off, locate the 4.3 mm silver screw near the top of the camera and remove it using the Phillips #00 screwdriver.
  9. Nikon COOLPIX P7700 Focusing Screen Replacement: paso 9, imagen 1 de 1
    • Remove the metal sheet from the camera.
    • It is okay to remove the orange ribbon from the camera.
  10. Nikon COOLPIX P7700 Focusing Screen Replacement: paso 10, imagen 1 de 3 Nikon COOLPIX P7700 Focusing Screen Replacement: paso 10, imagen 2 de 3 Nikon COOLPIX P7700 Focusing Screen Replacement: paso 10, imagen 3 de 3
    • Remove the four 4.3 mm silver screws located on the ends of the chip using the Phillips #00 screwdriver.
  11. Nikon COOLPIX P7700 Focusing Screen Replacement: paso 11, imagen 1 de 2 Nikon COOLPIX P7700 Focusing Screen Replacement: paso 11, imagen 2 de 2
    • Remove the two 4.3 mm silver screws on the far right side of the camera using the Phillips #00 screwdriver.
  12. Nikon COOLPIX P7700 Focusing Screen Replacement: paso 12, imagen 1 de 2 Nikon COOLPIX P7700 Focusing Screen Replacement: paso 12, imagen 2 de 2
    • Lift and detach connector from board as shown.
  13. Nikon COOLPIX P7700 Focusing Screen Replacement: paso 13, imagen 1 de 1
    • Remove the board from the camera to locate lens opening
  14. Nikon COOLPIX P7700 Focusing Screen Replacement: paso 14, imagen 1 de 1
    • Remove the 4.3 mm screws from the metal sheet using the Phillips #00 screwdriver.
  15. Nikon COOLPIX P7700 Focusing Screen Replacement: paso 15, imagen 1 de 1
    • Lift the metal sheet up and out of the camera.
  16. Nikon COOLPIX P7700 Focusing Screen Replacement: paso 16, imagen 1 de 1
    • Locate the reflective lens.
  17. Nikon COOLPIX P7700 Focusing Screen Replacement: paso 17, imagen 1 de 1
    • Remove the lens from the camera.
Conclusión
2 personas más completaron esta guía.
Dustin Wahl
Miembro Desde 03/11/15
784 Reputación
4 Guías creadas
Equipo
2 comentarios
Hey I have a P7700 that shows a lens error and focusing doesn't work.
I took it apart and removed the focus motor and it seems that the focus lens moves as it should but when turning it on the picture will be blurry for a second until the lens error comes up.
What issue is fixed by replacing this focus lens?
Dominik Bessler - Contestar
Hello.
Do you have a service procedure to fix the exposure dial in this camera?
Hugo - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 9
Ultimos 30 días: 16
Todo El Tiempo: 2,008
