Saltar al contenido principal
Nikon COOLPIX P500 Rear Case Replacement
Qué necesitas
  1. Nikon COOLPIX P500 Rear Case Replacement, Battery: paso 1, imagen 1 de 2 Nikon COOLPIX P500 Rear Case Replacement, Battery: paso 1, imagen 2 de 2
    • Electric shock is a huge risk if the battery is not removed while taking the camera apart.
    • Press down and forward on the battery cover latch.
    • Push the orange latch, in the direction of the arrow on it, to release the battery.
  2. Nikon COOLPIX P500 Rear Case Replacement, Rear Case: paso 2, imagen 1 de 3 Nikon COOLPIX P500 Rear Case Replacement, Rear Case: paso 2, imagen 2 de 3 Nikon COOLPIX P500 Rear Case Replacement, Rear Case: paso 2, imagen 3 de 3
    • Remove the marked 3mm screws.
    • Separate the two parts of the body of the camera slightly.
    • Make sure not to pull too hard because there are connector ribbons.
    • Detach the connector ribbons before fully separating the camera into two pieces.
  3. Nikon COOLPIX P500 Rear Case Replacement: paso 3, imagen 1 de 1
    • Remove the labeled 3mm screws using a PH00 screwdriver.
  4. Nikon COOLPIX P500 Rear Case Replacement: paso 4, imagen 1 de 1
    • Remove the brown metal plate.
Conclusión
Kevin Scott
Miembro Desde 01/22/15
457 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 19-10, Maness Winter 2015 Miembro de Cal Poly, Team 19-10, Maness Winter 2015
CPSU-MANESS-W15S19G10
4 Miembros
11 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 6
Todo El Tiempo: 985
