Saltar al contenido principal
Nikon COOLPIX P2 Case Replacement
Qué necesitas
  1. Nikon COOLPIX P2 Case Replacement, Case: paso 1, imagen 1 de 1
    • Remove the screw located near the speaker port using a Phillips 00 screwdriver.
  2. Nikon COOLPIX P2 Case Replacement: paso 2, imagen 1 de 1
    • Turn camera upside down so that the battery compartment is facing you.
    • Remove all four screws from the bottom of the camera with a Phillips 00 screwdriver.
  3. Nikon COOLPIX P2 Case Replacement: paso 3, imagen 1 de 1
    • Rotate the camera to the opposite side where the A/V outlet is located.
    • Unscrew and remove all four screws with a Phillips 00 screwdriver.
  4. Nikon COOLPIX P2 Case Replacement: paso 4, imagen 1 de 1
    • Turn the camera so that the Wi-Fi adapter is facing you.
  5. Nikon COOLPIX P2 Case Replacement: paso 5, imagen 1 de 3 Nikon COOLPIX P2 Case Replacement: paso 5, imagen 2 de 3 Nikon COOLPIX P2 Case Replacement: paso 5, imagen 3 de 3
    • Using a plastic opening tool, pry the front casing of the camera.
    • Continue this motion all around the front casing of the camera.
    • Gently pull apart the front casing from the rest of the camera.
  6. Nikon COOLPIX P2 Case Replacement: paso 6, imagen 1 de 1
    • Using the plastic opening tool pry the back casing of the camera.
  7. Nikon COOLPIX P2 Case Replacement: paso 7, imagen 1 de 1
    • Orange ribbon is fragile
    • Carefully pull apart the back casing of the camera from the front of the camera without tearing the orange ribbon.
  8. Nikon COOLPIX P2 Case Replacement: paso 8, imagen 1 de 2 Nikon COOLPIX P2 Case Replacement: paso 8, imagen 2 de 2
    • Pull down the on the black latch to carefully separate the orange ribbon from the motherboard.
    • Pull apart the orange ribbon and front casing from the rest of the camera.
Conclusión
Jessica Brough
Miembro Desde 01/22/12
135 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 3-28, Amido Winter 2012 Miembro de Cal Poly, Team 3-28, Amido Winter 2012
CPSU-AMIDO-W12S3G28
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 11
Todo El Tiempo: 1,128
