Saltar al contenido principal
Nikon 1 J3 LCD Screen Replacement
Qué necesitas
  1. Nikon 1 J3 LCD Screen Replacement, LCD Screen: paso 1, imagen 1 de 2 Nikon 1 J3 LCD Screen Replacement, LCD Screen: paso 1, imagen 2 de 2
    • Using a Phillips #000 screwdriver, remove the three bottom screws connected to the back plate on the bottom of the device.
    • Remove the screws under the flaps covering the HDMI and mini USB ports.
  2. Nikon 1 J3 LCD Screen Replacement: paso 2, imagen 1 de 1
    • Carefully pry back the back plate.
    • The plastic of the back plate may crack.
  3. Nikon 1 J3 LCD Screen Replacement: paso 3, imagen 1 de 1
    • Lift up the screen, and use a Phillips #000 screwdriver to remove the (6) six screws holding down the underlying metal plate.
  4. Nikon 1 J3 LCD Screen Replacement: paso 4, imagen 1 de 1
    • Pull back the black switch holding the orange screen ribbon in place, and remove the screen.
Conclusión
Austin Lackey
Miembro Desde 09/26/17
479 Reputación
4 Guías creadas
Equipo
USF Tampa, Team S11-G4, Passmore Fall 2017 Miembro de USF Tampa, Team S11-G4, Passmore Fall 2017
USFT-PASSMORE-F17S11G4
3 Miembros
4 Guías creadas
3 comentarios
Hey, I’m having trouble removing the back plate on step 2. It seems to be stuck on the side opposite the HDMI and USB ports, any tips for removing it? Thanks!
johnjames460 - Contestar
Step 1 seems to mis removal of 2 screws. Check tutorial below:
https://www.lifepixel.com/tutorials/infr...
Marcel Rossewij - Contestar
I am about to replace the lcd screen on my J4 - is the method the same as for the J3? And do I need any adhesive?
Nicholas Glover - 2nd April 2023
Nicholas Glover - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 13
Todo El Tiempo: 1,181
