Introducción
The LCD screen is what allows you to see what you're capturing so if it's broken you can't really use the camera. This guide will show you how to replace the LCD screen correctly.
Qué necesitas
Using the Phillips PH00 screwdriver, remove the six 4.0mm screws marked in red. Then remove the panel cover by lightly pulling it off.
Use a Phillips PH00 screwdriver to remove the 3.8mm screw in red.
Use a Phillips PH00 screwdriver to remove the 4.9mm screw in orange.
Use a Torx T4 screwdriver to remove the four 5.5mm screws in yellow.
Use a Phillips PH00 screwdriver to remove the seven 3.1mm screws marked in red.
Use a Phillips PH00 screwdriver to remove the two 3.6mm screws marked in orange.
Lift off the small plate as shown.
Lift the rainbow cable to have access to the 3.1mm screw beneath it and unscrew it with a Phillips PH00 screwdriver.
You will need to lift the sticky patch inside the the yellow rectangle, to access the 3.1mm screw marked in orange, remove it with Phillips PH00 screwdriver, then you will be able to separate the LCD screen from the rear panel.
3 personas más completaron esta guía.
