Saltar al contenido principal
Nike SportWatch GPS Unit Replacement
Qué necesitas
  1. Nike SportWatch GPS Unit Replacement, GPS Unit: paso 1, imagen 1 de 1
    • Using a size #000 Phillips screwdriver, remove the six 5 mm screws on the back of the device.
  2. Nike SportWatch GPS Unit Replacement: paso 2, imagen 1 de 1
    • Then, gently pull the watch band and front screen apart.
  3. Nike SportWatch GPS Unit Replacement: paso 3, imagen 1 de 1
    • Using a size #000 Phillips screwdriver, remove the two 2.5 mm screws on the main board.
  4. Nike SportWatch GPS Unit Replacement: paso 4, imagen 1 de 1
    • Carefully, use the blue plastic opening tool to pry the main board out of the front panel.
    • Make sure to be gentle so the ribbon cable that connects to the band does not break, it is fragile and is not removable.
  5. Nike SportWatch GPS Unit Replacement: paso 5, imagen 1 de 1
    • Use a spudger, to remove the orange tape that covers the wire for the GPS.
  6. Nike SportWatch GPS Unit Replacement: paso 6, imagen 1 de 1
    • Using the soldering iron, break the wire connecting the GPS to the main board at the connector.
    • When you are reassembling the watch, you will have to solder the wire back together.
  7. Nike SportWatch GPS Unit Replacement: paso 7, imagen 1 de 1
    • Use the plastic opening tool to pry out the GPS unit.
Conclusión
Una persona más ha completado esta guía.
Ian Eichorn
Miembro Desde 10/22/15
678 Reputación
4 Guías creadas
Equipo
UMass Dartmouth, Team 5-8, Gulbrandsen Fall 2015 Miembro de UMass Dartmouth, Team 5-8, Gulbrandsen Fall 2015
UMASSD-GULBRANDSEN-F15S5G8
3 Miembros
5 Guías creadas
3 comentarios
which GPS unit is it?
charles - Contestar
what gps unit is it?
charles - Contestar
I would also like to know what GPS unit that is and if it is possible to find a replacement or a compatible unit?
avs4820 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 10
Todo El Tiempo: 1,878
