Saltar al contenido principal
Nike SportWatch GPS Front Panel Replacement
Qué necesitas
  1. Nike SportWatch GPS Front Panel Replacement, Front Panel: paso 1, imagen 1 de 1
    • Face the watch upside down so that the back of the watch is exposed. Unscrew the six size #000 5 mm long screws on the back using a size 000 Phillips head screwdriver.
  2. Nike SportWatch GPS Front Panel Replacement: paso 2, imagen 1 de 1
    • Carefully separate the watch by pulling the band away from the main board.
  3. Nike SportWatch GPS Front Panel Replacement: paso 3, imagen 1 de 1
    • Two size #000 2.5 mm long screws will appear at the top of the main board. Unscrew them using a size 000 Phillips head screwdriver.
  4. Nike SportWatch GPS Front Panel Replacement: paso 4, imagen 1 de 1
    • Carefully use the blue plastic opening tool to pry the main board out of the front panel.
    • Make sure to be gentle so the ribbon cable that connects to the band does not break, it is fragile and not removable.
  5. Nike SportWatch GPS Front Panel Replacement: paso 5, imagen 1 de 1
    • Use an iOpener that has been heated in the microwave for about a minute, or until warm. Place it on the front screen of the watch. Let it rest there for a minute.
    • If you are unfamiliar with this tool use the iOpener guide here
  6. Nike SportWatch GPS Front Panel Replacement: paso 6, imagen 1 de 1
    • Push the panel out from the back of the screen, using your fingers.
Conclusión
Ian Eichorn
Miembro Desde 10/22/15
678 Reputación
4 Guías creadas
Equipo
UMass Dartmouth, Team 5-8, Gulbrandsen Fall 2015 Miembro de UMass Dartmouth, Team 5-8, Gulbrandsen Fall 2015
UMASSD-GULBRANDSEN-F15S5G8
3 Miembros
5 Guías creadas
Un comentario
Where I can find the replacement glass? regards
Erick Sobreiro - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 6
Todo El Tiempo: 1,275
