Introducción
If your battery is dying, you may have to replace it. Follow this guide to take the watch apart and replace the battery.
Qué necesitas
Face the watch upside down, so that the back of the watch is exposed. Unscrew the six size #000 5 mm long screws using a size 000 Phillips head screwdriver.
To reassemble your device, follow these instructions in reverse order. Once reassembled, plug the watch back into a USB computer port to turn the watch back on and start the initial charge. Let charge to full capacity.
9 personas más completaron esta guía.
8 comentarios
Where can i buy a replacement battery?
Looks like you can buy them on ebay: http://www.ebay.com/itm/-/131819485344?
Thank you for this guide and the link to the replacement battery.
The battery I received had an extra circuit board and the contacts/metal bands were thinner and further apart thus making direct replacement difficult, there was no way to create proper connection with the spring contacts using the black plastic pc . I ended up removing the extra PCB and soldered the battery with short leads directly to the spring contacts and this worked well.
Unfortunately, it seems the battery wasn't the only issue with the watch.. last night it was fully charged however by this morning it was almost totally empty.
