Saltar al contenido principal
Nike SportWatch GPS Back Panel Replacement
Qué necesitas
  1. Nike SportWatch GPS Back Panel Replacement, Back Panel: paso 1, imagen 1 de 1
    • Face the watch upside down, so that the back of the watch is exposed. Unscrew the six #000 size 5 mm long screws on the back using a size 000 Phillips head screwdriver.
  2. Nike SportWatch GPS Back Panel Replacement: paso 2, imagen 1 de 1
    • Carefully separate the watch by pulling the band away from the main board.
  3. Nike SportWatch GPS Back Panel Replacement: paso 3, imagen 1 de 1
    • Pry the black plastic piece above the battery out using a nylon or metal spudger.
    • Be careful not to break the metal flat bands located above the plastic piece. They are fragile and easily breakable.
  4. Nike SportWatch GPS Back Panel Replacement: paso 4, imagen 1 de 1
    • Using a guitar pick removal tool, push under the battery to pry the battery out of the watch.
  5. Nike SportWatch GPS Back Panel Replacement: paso 5, imagen 1 de 1
    • After taking the battery out, you will be left with just the band and the backpanel part of the watch.
Conclusión
Una persona más ha completado esta guía.
Ian Eichorn
Miembro Desde 10/22/15
678 Reputación
4 Guías creadas
Equipo
UMass Dartmouth, Team 5-8, Gulbrandsen Fall 2015 Miembro de UMass Dartmouth, Team 5-8, Gulbrandsen Fall 2015
UMASSD-GULBRANDSEN-F15S5G8
3 Miembros
5 Guías creadas
3 comentarios
Where can I find a new watch band?
rhalljr68 - Contestar
You can´t. Nike left us alone
Leonardo Cartier - Contestar
So, no way to repair the band then if there's no replacement parts? :(
roycy Tan - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 2,543
