Saltar al contenido principal
Nike+ Sportband Motherboard Replacement
Qué necesitas
  1. Nike+ Sportband Motherboard Replacement, External Case: paso 1, imagen 1 de 2 Nike+ Sportband Motherboard Replacement, External Case: paso 1, imagen 2 de 2
    • To begin the disassembly of your NikePlus Sportband, first remove the device from the rubber wristband.
  2. Nike+ Sportband Motherboard Replacement: paso 2, imagen 1 de 2 Nike+ Sportband Motherboard Replacement: paso 2, imagen 2 de 2
    • Finish the disassembly of your NikePlus Sportband by utilizing the metal spudger tool on the short edge to pry the external body pieces apart.
  3. Nike+ Sportband Motherboard Replacement, Screen: paso 3, imagen 1 de 2 Nike+ Sportband Motherboard Replacement, Screen: paso 3, imagen 2 de 2
    • After the cover had been removed, use the metal spudger tool to remove the body of the device from the casing.
  4. Nike+ Sportband Motherboard Replacement: paso 4, imagen 1 de 3 Nike+ Sportband Motherboard Replacement: paso 4, imagen 2 de 3 Nike+ Sportband Motherboard Replacement: paso 4, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Use the metal tweezers to pry the screen casing from the body of the device.
    • The screen casing is fastened to the body of the device by four clips located in each corner of the casing.
  5. Nike+ Sportband Motherboard Replacement: paso 5, imagen 1 de 2 Nike+ Sportband Motherboard Replacement: paso 5, imagen 2 de 2
    • Flip the body of the device over so that the screen is now on the bottom.
    • The display ribbon cable is soldered to the motherboard. We were able to peel up the ribbon cable with a pair of tweezers.
    • Successfully resoldering this ribbon cable to the motherboard may prove difficult to the very small traces.
  6. Nike+ Sportband Motherboard Replacement: paso 6, imagen 1 de 3 Nike+ Sportband Motherboard Replacement: paso 6, imagen 2 de 3 Nike+ Sportband Motherboard Replacement: paso 6, imagen 3 de 3
    • Flip the body of the device back over so that the screen is facing up.
    • Using the tweezers, gently lift the screen from body of the device.
  7. Nike+ Sportband Motherboard Replacement, Motherboard: paso 7, imagen 1 de 1
    • Remove the four highlighted screws from the motherboard using the Philips screwdriver.
  8. Nike+ Sportband Motherboard Replacement: paso 8, imagen 1 de 3 Nike+ Sportband Motherboard Replacement: paso 8, imagen 2 de 3 Nike+ Sportband Motherboard Replacement: paso 8, imagen 3 de 3
    Comprar
    • Use the metal tweezers to lift the motherboard out of the device.
Conclusión
Alyssa Setnar
Miembro Desde 02/15/16
331 Reputación
3 Guías creadas
Equipo
IUPUI, Team 9-9, Wilson Spring 2016 Miembro de IUPUI, Team 9-9, Wilson Spring 2016
IUPUI-WILSON-S16S9G9
5 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 6
Todo El Tiempo: 265
