Introducción
In this repair guide we will guide you through the steps necessary to remove and replace the battery found within the NikePlus Sportband.
Qué necesitas
To begin the disassembly of your NikePlus Sportband, first remove the device from the rubber wristband.
After the cover had been removed, use the metal spudger tool to remove the body of the device from the casing.
Remove the four highlighted screws from the motherboard using the Philips screwdriver.
Slowly lift the motherboard off of the mounting body of the band with a pair of tweezers.
Gently lay the motherboard upside down exposing the underside of the motherboard.
The red and black battery wires may need to be desoldered from the board. Check out the How To Solder and Desolder Connections guide for some helpful tips on this.
Using the flat edge of a spudger separate the battery from the body of the band.
Una persona más ha completado esta guía.
