Introducción
This guide will help you replace the speaker in your Nexus S.
Partes
No se requieren partes.
Gently insert a plastic opening tool between the rear panel and the inner rear frame near the rear-facing camera.
Use your plastic opening tool to pry up the rear case around the perimeter of the Nexus S.
Using the edge of a plastic opening tool, lift the battery from the end closest to the headphone jack.
Remove the battery from the Nexus S.
Use your thumb to slide the SIM card downwards from the SIM card slot.
Remove the SIM card.
Remove the six Phillips screws securing the rear inner frame to the inner case.
Use the flat edge of a plastic opening tool to pry the SIM Board connector off its socket on the motherboard.
Wedge the edge of a plastic opening tool underneath the SIM Card board and motherboard.
Pry the clips located near the right bottom edge of the SIM Card board up off the motherboard.
Repeat the process all along the bottom perimeter of the SIM Card board until all clips have been disengaged.
Disconnect the following cables from their respective sockets on the motherboard:
Headphone jack cable
Digitizer cable connector
Camera/SIM board connector
7 personas más completaron esta guía.
3 Comentarios
Where can I buy the speaker?
Hi, I bought a replacement for my speaker(it's dead) but, the replacement did not come with an earpiece. Can I take the earpiece from my old one and attach it to the new one. I have some soldering experience.
hey makenova,
I have the same problem. Did the soldering worked for you ?
