Saltar al contenido principal
Nexus S SIM Card Replacement
Qué necesitas
  1. Nexus S SIM Card Replacement, Rear Panel: paso 1, imagen 1 de 1
    • Gently insert a plastic opening tool between the rear panel and the inner rear frame near the rear-facing camera.
    • Use your plastic opening tool to pry up the rear case around the perimeter of the Nexus S.
  2. Nexus S SIM Card Replacement: paso 2, imagen 1 de 1
    • Remove the rear panel from the Nexus S.
  3. Nexus S SIM Card Replacement, Battery: paso 3, imagen 1 de 1
    • Using the edge of a plastic opening tool, lift the battery from the end closest to the headphone jack.
    • Remove the battery from the Nexus S.
  4. Nexus S SIM Card Replacement, SIM Card: paso 4, imagen 1 de 2 Nexus S SIM Card Replacement, SIM Card: paso 4, imagen 2 de 2
    • Use your thumb to slide the SIM card downwards from the SIM card slot.
    • Remove the SIM card.
Conclusión
5 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 8
Todo El Tiempo: 7,417
