Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Nexus S SIM Card Board Replacement
Qué necesitas
    1. Nexus S SIM Card Board Replacement, Rear Panel: paso 1, imagen 1 de 1
      • Gently insert a plastic opening tool between the rear panel and the inner rear frame near the rear-facing camera.
      • Use your plastic opening tool to pry up the rear case around the perimeter of the Nexus S.
      Pregunta a FixBot
      Agregar Comentario
    2. Nexus S SIM Card Board Replacement: paso 2, imagen 1 de 1
      • Remove the rear panel from the Nexus S.
      Pregunta a FixBot
      Agregar Comentario
    1. Nexus S SIM Card Board Replacement, Battery: paso 3, imagen 1 de 1
      • Using the edge of a plastic opening tool, lift the battery from the end closest to the headphone jack.
      • Remove the battery from the Nexus S.
      Pregunta a FixBot
      Agregar Comentario
    1. Nexus S SIM Card Board Replacement, SIM Card: paso 4, imagen 1 de 2 Nexus S SIM Card Board Replacement, SIM Card: paso 4, imagen 2 de 2
      • Use your thumb to slide the SIM card downwards from the SIM card slot.
      • Remove the SIM card.
      Pregunta a FixBot
      Agregar Comentario
    1. Nexus S SIM Card Board Replacement, Rear Inner Frame: paso 5, imagen 1 de 1
      • Remove the six Phillips screws securing the rear inner frame to the inner case.
      Pregunta a FixBot
      Agregar Comentario
    2. Nexus S SIM Card Board Replacement: paso 6, imagen 1 de 1
      • Insert the flat edge of a plastic opening tool in between the rear inner frame and the top left corner of the Nexus S.
      • Pry the opening tool upwards to pop the top right corner from the clips securing it to the inner assembly.
      Pregunta a FixBot
      Agregar Comentario
    3. Nexus S SIM Card Board Replacement: paso 7, imagen 1 de 2 Nexus S SIM Card Board Replacement: paso 7, imagen 2 de 2
      • Insert the plastic opening tool to the right of the power button.
      • Slide the plastic opening tool downwards along the perimeter of the Nexus S to release the clips on the right side.
      Pregunta a FixBot
      Agregar Comentario
    4. Nexus S SIM Card Board Replacement: paso 8, imagen 1 de 2 Nexus S SIM Card Board Replacement: paso 8, imagen 2 de 2
      • In the same manner as previously described, release the bottom clips located near the bottom of the Nexus S.
      Pregunta a FixBot
      Agregar Comentario
    5. Nexus S SIM Card Board Replacement: paso 9, imagen 1 de 1
      • Insert and pry the plastic opening tool to release the final clip securing the rear inner frame to the inner assembly.
      Pregunta a FixBot
      Agregar Comentario
    6. Nexus S SIM Card Board Replacement: paso 10, imagen 1 de 1
      • Lift and remove the rear inner frame from the Nexus S.
      Pregunta a FixBot
      Agregar Comentario
    1. Nexus S SIM Card Board Replacement, SIM Card Board: paso 11, imagen 1 de 1
      • Use the flat edge of a plastic opening tool to pry the SIM Board connector off its socket on the motherboard.
      Pregunta a FixBot
      Agregar Comentario
    2. Nexus S SIM Card Board Replacement: paso 12, imagen 1 de 3 Nexus S SIM Card Board Replacement: paso 12, imagen 2 de 3 Nexus S SIM Card Board Replacement: paso 12, imagen 3 de 3
      • Wedge the edge of a plastic opening tool underneath the SIM Card board and motherboard.
      • Pry the clips located near the right bottom edge of the SIM Card board up off the motherboard.
      • Repeat the process all along the bottom perimeter of the SIM Card board until all clips have been disengaged.
      Pregunta a FixBot
      Agregar Comentario
    3. Nexus S SIM Card Board Replacement: paso 13, imagen 1 de 1
      • Lift and remove the SIM Card board out of the Nexus S.
      Pregunta a FixBot
      Agregar Comentario
    1. Nexus S SIM Card Board Replacement, SIM Card Board: paso 14, imagen 1 de 1
      • SIM Card board remains.
      Pregunta a FixBot
      Agregar Comentario
Conclusión
14 personas más completaron esta guía.
4Guía Comentarios
Where can I buy this part ? (Nexus S SIM Card Board ) ?
Andre Venancio - Contestar Compartir
고액토토먹튀검증 완료 . 고액토토 환전 책임지고 먹튀검증 해드립니다. 소액부터 고액까지 안전이 제일우선 먹튀타임즈에서 함께하세요
timesjs01 - Contestar Compartir
I simply want to mention I am very new to blogging and seriously savored this web page. Likely I’m going to bookmark your blog post . You amazingly come with fantastic writings. Appreciate it for revealing your blog. 먹튀검증업체
먹튀타임즈에서 먹튀검증업체를 여러분께 추천드립니다
모두 직접 연락이 가능한 안전한 먹튀검증업체입니다.
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 26
Ultimos 30 días: 46
Todo El Tiempo: 9,374
