Saltar al contenido principal
Nexus S Rear Inner Frame Replacement
Qué necesitas
  1. Nexus S Rear Inner Frame Replacement, Rear Panel: paso 1, imagen 1 de 1
    • Gently insert a plastic opening tool between the rear panel and the inner rear frame near the rear-facing camera.
    • Use your plastic opening tool to pry up the rear case around the perimeter of the Nexus S.
  2. Nexus S Rear Inner Frame Replacement: paso 2, imagen 1 de 1
    • Remove the rear panel from the Nexus S.
  3. Nexus S Rear Inner Frame Replacement, Battery: paso 3, imagen 1 de 1
    • Using the edge of a plastic opening tool, lift the battery from the end closest to the headphone jack.
    • Remove the battery from the Nexus S.
  4. Nexus S Rear Inner Frame Replacement, SIM Card: paso 4, imagen 1 de 2 Nexus S Rear Inner Frame Replacement, SIM Card: paso 4, imagen 2 de 2
    • Use your thumb to slide the SIM card downwards from the SIM card slot.
    • Remove the SIM card.
  5. Nexus S Rear Inner Frame Replacement, Rear Inner Frame: paso 5, imagen 1 de 1
    • Remove the six Phillips screws securing the rear inner frame to the inner case.
  6. Nexus S Rear Inner Frame Replacement: paso 6, imagen 1 de 1
    • Insert the flat edge of a plastic opening tool in between the rear inner frame and the top left corner of the Nexus S.
    • Pry the opening tool upwards to pop the top right corner from the clips securing it to the inner assembly.
  7. Nexus S Rear Inner Frame Replacement: paso 7, imagen 1 de 2 Nexus S Rear Inner Frame Replacement: paso 7, imagen 2 de 2
    • Insert the plastic opening tool to the right of the power button.
    • Slide the plastic opening tool downwards along the perimeter of the Nexus S to release the clips on the right side.
  8. Nexus S Rear Inner Frame Replacement: paso 8, imagen 1 de 2 Nexus S Rear Inner Frame Replacement: paso 8, imagen 2 de 2
    • In the same manner as previously described, release the bottom clips located near the bottom of the Nexus S.
  9. Nexus S Rear Inner Frame Replacement: paso 9, imagen 1 de 1
    • Insert and pry the plastic opening tool to release the final clip securing the rear inner frame to the inner assembly.
  10. Nexus S Rear Inner Frame Replacement: paso 10, imagen 1 de 1
    • Lift and remove the rear inner frame from the Nexus S.
  11. Nexus S Rear Inner Frame Replacement, Rear Inner Frame: paso 11, imagen 1 de 1
    • Rear inner frame remains.
Conclusión
4 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 15
Todo El Tiempo: 3,028
