Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Nexus S Rear Camera Replacement
Qué necesitas
  1. Nexus S Rear Camera Replacement, Rear Panel: paso 1, imagen 1 de 1
    • Gently insert a plastic opening tool between the rear panel and the inner rear frame near the rear-facing camera.
    • Use your plastic opening tool to pry up the rear case around the perimeter of the Nexus S.
    Pregunta a FixBot
    Agregar Comentario
  2. Nexus S Rear Camera Replacement: paso 2, imagen 1 de 1
    • Remove the rear panel from the Nexus S.
    Pregunta a FixBot
    Agregar Comentario
  3. Nexus S Rear Camera Replacement, Battery: paso 3, imagen 1 de 1
    • Using the edge of a plastic opening tool, lift the battery from the end closest to the headphone jack.
    • Remove the battery from the Nexus S.
    Pregunta a FixBot
    Agregar Comentario
  4. Nexus S Rear Camera Replacement, SIM Card: paso 4, imagen 1 de 2 Nexus S Rear Camera Replacement, SIM Card: paso 4, imagen 2 de 2
    • Use your thumb to slide the SIM card downwards from the SIM card slot.
    • Remove the SIM card.
    Pregunta a FixBot
    Agregar Comentario
  5. Nexus S Rear Camera Replacement, Rear Inner Frame: paso 5, imagen 1 de 1
    • Remove the six Phillips screws securing the rear inner frame to the inner case.
    Pregunta a FixBot
    Agregar Comentario
  6. Nexus S Rear Camera Replacement: paso 6, imagen 1 de 1
    • Insert the flat edge of a plastic opening tool in between the rear inner frame and the top left corner of the Nexus S.
    • Pry the opening tool upwards to pop the top right corner from the clips securing it to the inner assembly.
    Pregunta a FixBot
    Agregar Comentario
  7. Nexus S Rear Camera Replacement: paso 7, imagen 1 de 2 Nexus S Rear Camera Replacement: paso 7, imagen 2 de 2
    • Insert the plastic opening tool to the right of the power button.
    • Slide the plastic opening tool downwards along the perimeter of the Nexus S to release the clips on the right side.
    Pregunta a FixBot
    Agregar Comentario
  8. Nexus S Rear Camera Replacement: paso 8, imagen 1 de 2 Nexus S Rear Camera Replacement: paso 8, imagen 2 de 2
    • In the same manner as previously described, release the bottom clips located near the bottom of the Nexus S.
    Pregunta a FixBot
    Agregar Comentario
  9. Nexus S Rear Camera Replacement: paso 9, imagen 1 de 1
    • Insert and pry the plastic opening tool to release the final clip securing the rear inner frame to the inner assembly.
    Pregunta a FixBot
    Agregar Comentario
  10. Nexus S Rear Camera Replacement: paso 10, imagen 1 de 1
    • Lift and remove the rear inner frame from the Nexus S.
    Pregunta a FixBot
    Agregar Comentario
  11. Nexus S Rear Camera Replacement, SIM Card Board: paso 11, imagen 1 de 1
    • Use the flat edge of a plastic opening tool to pry the SIM Board connector off its socket on the motherboard.
    Pregunta a FixBot
    Agregar Comentario
  12. Nexus S Rear Camera Replacement: paso 12, imagen 1 de 3 Nexus S Rear Camera Replacement: paso 12, imagen 2 de 3 Nexus S Rear Camera Replacement: paso 12, imagen 3 de 3
    • Wedge the edge of a plastic opening tool underneath the SIM Card board and motherboard.
    • Pry the clips located near the right bottom edge of the SIM Card board up off the motherboard.
    • Repeat the process all along the bottom perimeter of the SIM Card board until all clips have been disengaged.
    Pregunta a FixBot
    Agregar Comentario
  13. Nexus S Rear Camera Replacement: paso 13, imagen 1 de 1
    • Lift and remove the SIM Card board out of the Nexus S.
    Pregunta a FixBot
    Agregar Comentario
  14. Nexus S Rear Camera Replacement, Motherboard: paso 14, imagen 1 de 1
    • Insert the flat edge of a plastic opening tool underneath the headphone jack connector and pry upwards.
    Pregunta a FixBot
    Agregar Comentario
  15. Nexus S Rear Camera Replacement: paso 15, imagen 1 de 1
    • Repeat the same procedure as the previous step to disconnect the digitizer connector.
    Pregunta a FixBot
    Agregar Comentario
  16. Nexus S Rear Camera Replacement: paso 16, imagen 1 de 1
    • Use a plastic opening tool to pry the speaker connector (highlighted in red) from its socket on the motherboard.
    • Remove the three Phillips screws securing the motherboard to the inner assembly.
    Pregunta a FixBot
    Agregar Comentario
  17. Nexus S Rear Camera Replacement: paso 17, imagen 1 de 1
    • Lift and remove the motherboard from the Nexus S, minding any cables that may get caught.
    Pregunta a FixBot
    Agregar Comentario
  18. Nexus S Rear Camera Replacement, Rear Camera: paso 18, imagen 1 de 2 Nexus S Rear Camera Replacement, Rear Camera: paso 18, imagen 2 de 2
    • Use the edge of plastic opening tool to flip up the rear facing camera ZIF connector.
    Pregunta a FixBot
    Agregar Comentario
  19. Nexus S Rear Camera Replacement: paso 19, imagen 1 de 1
    Herramienta utilizada en este paso:
    • Use a pair of tweezers to lift and remove the rear camera from the motherboard.
    Pregunta a FixBot
    Agregar Comentario
Conclusión
7 personas más completaron esta guía.
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 47
Todo El Tiempo: 3,771
