Saltar al contenido principal
Nexus Q LED Board Replacement
Qué necesitas
  1. Nexus Q LED Board Replacement, Ball Bearing Ring: paso 1, imagen 1 de 1
    • Squeeze and pull the cap to remove it from the Nexus Q.
  2. Nexus Q LED Board Replacement: paso 2, imagen 1 de 1
    • Use a spudger to disconnect the Taoglas Wi-Fi Dual Band Antenna.
  3. Nexus Q LED Board Replacement: paso 3, imagen 1 de 1
    • Undo the ZIF connector by prying it with a spudger.
  4. Nexus Q LED Board Replacement: paso 4, imagen 1 de 1
    • Use a Phillips #0 screwdriver to unscrew the four 1.3 mm screws.
    • After removing the screws, there will be two parts. The top part contains the daughterboard. Store it safely. It will not be used.
  5. Nexus Q LED Board Replacement: paso 5, imagen 1 de 1
    • View the bottom half of the Nexus Q.
    • Use a Phillips #0 screwdriver to remove the four 0.8 mm screws holding the ball bearing ring in place.
  6. Nexus Q LED Board Replacement: paso 6, imagen 1 de 1
    • Remove the ball bearing ring.
    • When placing a new ring in its place, make sure to orient it right or the top will not close.
  7. Nexus Q LED Board Replacement, LED Board: paso 7, imagen 1 de 2 Nexus Q LED Board Replacement, LED Board: paso 7, imagen 2 de 2
    • Once you remove the ball bearing ring from the bottom half of the Nexus Q, you will be exposed to a diffuser (white ring) held in with three T6 Torx screws.
    • Use a #0 Philips head screwdriver to remove the three 0.8 mm screws holding the diffuser in place.
  8. Nexus Q LED Board Replacement: paso 8, imagen 1 de 2 Nexus Q LED Board Replacement: paso 8, imagen 2 de 2
    • With the diffuser out, we are exposed to the LED Board.
    • Use a spudger to lightly lift the LED board out.
Conclusión
Taewan Kim
Miembro Desde 01/31/13
22 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 7-10, Maness Winter 2013 Miembro de Cal Poly, Team 7-10, Maness Winter 2013
CPSU-MANESS-W13S7G10
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 7
Todo El Tiempo: 513
