Saltar al contenido principal
Nexus Q Inner Dome Daughterboard Replacement
Qué necesitas
  1. Nexus Q Inner Dome Daughterboard Replacement, Taoglas PU18 Wi-Fi Dual Band Antenna: paso 1, imagen 1 de 1
    • Squeeze and pull to pop the cap off of the Nexus Q.
  2. Nexus Q Inner Dome Daughterboard Replacement: paso 2, imagen 1 de 2 Nexus Q Inner Dome Daughterboard Replacement: paso 2, imagen 2 de 2
    • Disconnect the taoglas Wi-Fi Dual Band Antenna by prying with a spudger.
    • Once the antenna is disconnected, simply pull it off the outside of the inner dome.
  3. Nexus Q Inner Dome Daughterboard Replacement, Inner Dome Daughterboard: paso 3, imagen 1 de 1
    • Undo the ZIF connector by prying with a spudger.
  4. Nexus Q Inner Dome Daughterboard Replacement: paso 4, imagen 1 de 1
    • Use a T10 Torx screwdriver to remove the four 1.3 mm screws holding the inner dome in place.
  5. Nexus Q Inner Dome Daughterboard Replacement: paso 5, imagen 1 de 1
    • Use a T6 Torx screwdriver to undo the three 0.8 mm screws holding the inner dome daughterboard in place.
  6. Nexus Q Inner Dome Daughterboard Replacement: paso 6, imagen 1 de 1
    • Use a spudger to disconnect the daughterboard from the ZIF connector.
Conclusión
Alex Thomas
Miembro Desde 01/31/13
27 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 7-10, Maness Winter 2013 Miembro de Cal Poly, Team 7-10, Maness Winter 2013
CPSU-MANESS-W13S7G10
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 901
