1. Using two fingers, push up on the rear cover.
    • Using two fingers, push up on the rear cover.
  2. The rear cover slides up and off.
    • The rear cover slides up and off.
    • Using the plastic opening tools, pry the left bottom corner of the battery up.
    • Pull the battery up and out.
    • Remove the two Torx T5 screws.
    • Remove the one Philips #00 screw.
    • Using the plastic opening tool, pry up the battery housing upwards.
    • Push pry tool down, undoing the plastic tab.
    • Pry the upper left tab open on the battery housing.
    • Pry the top tab of the battery housing.
    • Pry the right side tab of the battery housing.
    • Pull up on the battery housing.
    • Slide the battery housing out to remove it.
    • Using the plastic opening tool, push the blade into the space between the case and lower cover.
    • Turn the opening tool slightly, the lower cover will detach on that side.
    • Repeat on other side of the seam.
    • The lower cover will slide off.
    • Remove the one T5 Torx screw
    • Remove the one #00 Philips screw
    • Lift up the end of the antenna housing and slide it outwards.
    • Using the spudger, pry upwards on the second microphone connector.
    • Pull up on the ribbon cable, the tape will detach from the main board ribbon.
    • Pry the antenna cable up.
    • Carefully pull up on the microphone board to release the tape from the phone.
    • Insert the spudger under the connector.
    • Push the spudger up and twist to release the connector.
    • Repeat for the next connector.
    • Push on the USB port to expose the black connector.
    • Use the spudger to pry the connector upwards.
    • Place the spugder under the antenna connector.
    • Pry connector up vertically.
    • Insert the spudger into tab above the camera.
    • Slide upwards until the board detaches from the case.
    • Press the pointed tip of the spudger into the space below the button assembly.
    • Wiggle the spudger tip towards the outside of the button.
    • The button assembly is under some tension and may fly off.
    • Push the pointed tip of the spudger into the base of the side button board.
    • Lift up, the board will disconnect from the case.
    • Push on the lower motherboard until it slides under the case support.
    • The motherboard assembly comes out as a single piece.
    • Save the small black rubber rectangular sound guide under the motherboard, to replace over the microphone.
    • Remove the three #00 Philips screws from the trackball housing.
    • Using the spudger, pry up the trackball housing to expose the trackball assembly.
    • The trackball pushes out from the outside of the phone.
    • The trackball assembly only mounts a single way. The metal tab under the ball should hinge closest to the bottom of the phone. (RE-EDIT)
Conclusión
Niklas Johnson
Miembro Desde 31/01/12
1,063 Reputación
18 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 3,228
