Saltar al contenido principal
Nexus One Secondary Microphone Replacement
Qué necesitas
  1. Nexus One Secondary Microphone Replacement, Rear Cover: paso 1, imagen 1 de 2 Nexus One Secondary Microphone Replacement, Rear Cover: paso 1, imagen 2 de 2
    • Using two fingers, push up on the rear cover.
  2. Nexus One Secondary Microphone Replacement: paso 2, imagen 1 de 1
    • The rear cover slides up and off.
  3. Nexus One Secondary Microphone Replacement, Battery: paso 3, imagen 1 de 1
    • Using the plastic opening tools, pry the left bottom corner of the battery up.
  4. Nexus One Secondary Microphone Replacement: paso 4, imagen 1 de 1
    • Pull the battery up and out.
  5. Nexus One Secondary Microphone Replacement, Battery Housing: paso 5, imagen 1 de 1
    • Remove the two Torx T5 screws.
    • Remove the one Philips #00 screw.
  6. Nexus One Secondary Microphone Replacement: paso 6, imagen 1 de 2 Nexus One Secondary Microphone Replacement: paso 6, imagen 2 de 2
    • Using the plastic opening tool, pry up the battery housing upwards.
    • Push pry tool down, undoing the plastic tab.
  7. Nexus One Secondary Microphone Replacement: paso 7, imagen 1 de 2 Nexus One Secondary Microphone Replacement: paso 7, imagen 2 de 2
    • Pry the upper left tab open on the battery housing.
  8. Nexus One Secondary Microphone Replacement: paso 8, imagen 1 de 2 Nexus One Secondary Microphone Replacement: paso 8, imagen 2 de 2
    • Pry the top tab of the battery housing.
  9. Nexus One Secondary Microphone Replacement: paso 9, imagen 1 de 2 Nexus One Secondary Microphone Replacement: paso 9, imagen 2 de 2
    • Pry the right side tab of the battery housing.
  10. Nexus One Secondary Microphone Replacement: paso 10, imagen 1 de 2 Nexus One Secondary Microphone Replacement: paso 10, imagen 2 de 2
    • Pull up on the battery housing.
    • Slide the battery housing out to remove it.
  11. Nexus One Secondary Microphone Replacement, Secondary Microphone: paso 11, imagen 1 de 2 Nexus One Secondary Microphone Replacement, Secondary Microphone: paso 11, imagen 2 de 2
    • Using the spudger, pry upwards on the second microphone connector.
  12. Nexus One Secondary Microphone Replacement: paso 12, imagen 1 de 1
    • Pull up on the ribbon cable, the tape will detach from the main board ribbon.
Conclusión
Niklas Johnson
Miembro Desde 01/31/12
1,207 Reputación
18 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 11
Todo El Tiempo: 2,267
