Using two fingers, push up on the rear cover.
  • Using two fingers, push up on the rear cover.
Agregar Comentario
The rear cover slides up and off.
  • The rear cover slides up and off.
Agregar Comentario
  • Using the plastic opening tools, pry the left bottom corner of the battery up.
Agregar Comentario
  • Pull the battery up and out.
Agregar Comentario
  • Remove the two Torx T5 screws.
  • Remove the one Philips #00 screw.
#0 Phillis screw
skuhry - Contestar
  • Using the plastic opening tool, pry up the battery housing upwards.
  • Push pry tool down, undoing the plastic tab.
Agregar Comentario
  • Pry the upper left tab open on the battery housing.
Agregar Comentario
  • Pry the top tab of the battery housing.
Agregar Comentario
  • Pry the right side tab of the battery housing.
Agregar Comentario
  • Pull up on the battery housing.
  • Slide the battery housing out to remove it.
Agregar Comentario
  • Using the plastic opening tool, push the blade into the space between the case and lower cover.
  • Turn the opening tool slightly, the lower cover will detach on that side.
  • Repeat on other side of the seam.
  • The lower cover will slide off.
Agregar Comentario
  • Remove the one T5 Torx screw
  • Remove the one #00 Philips screw
  • Lift up the end of the antenna housing and slide it outwards.
Agregar Comentario
  • Pry the antenna cable up.
Agregar Comentario
  • Carefully pull up on the microphone board to release the tape from the phone.
Agregar Comentario
  • Insert the spudger under the connector.
  • Push the spudger up and twist to release the connector.
  • Repeat for the next connector.
Agregar Comentario
  • Push on the USB port to expose the black connector.
  • Use the spudger to pry the connector upwards.
The philips screw holding down the logic board (at the lower right corner in the picture) has to be removed before the board can be pushed back.
Mark - Contestar
  • Place the spugder under the antenna connector.
  • Pry connector up vertically.
Agregar Comentario
  • Insert the spudger into tab above the camera.
  • Slide upwards until the board detaches from the case.
A philips screw holding down the upper logic board (in the lower left corner of the picture) must be remobed before the board can be detached.
Mark - Contestar
  • Press the pointed tip of the spudger into the space below the button assembly.
  • Wiggle the spudger tip towards the outside of the button.
  • The button assembly is under some tension and may fly off.
Agregar Comentario
  • Push the pointed tip of the spudger into the base of the side button board.
  • Lift up, the board will disconnect from the case.
Agregar Comentario
  • Push on the lower motherboard until it slides under the case support.
  • The motherboard assembly comes out as a single piece.
  • Save the small black rubber rectangular sound guide under the motherboard, to replace over the microphone.
Be carefull not to tear the home button cable that is in the top right corner!!
zack - Contestar
  • Remove the seven #00 Philips screws
Agregar Comentario
  • Use the spudger to pop the 3 latches holding the screen down.
Agregar Comentario
  • Pull up on the screen so it slides out of the case.
Agregar Comentario
  • Make sure to peel off the digitizer connector from the back of the LCD
Agregar Comentario
Conclusión
5 personas más completaron esta guía.
Niklas Johnson
Miembro Desde 31/01/12
1,063 Reputación
18 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 4
Todo El Tiempo: 7,461
