1. Using two fingers, push up on the rear cover. Using two fingers, push up on the rear cover.
    • Using two fingers, push up on the rear cover.
  2. The rear cover slides up and off.
    • The rear cover slides up and off.
  3. Using the plastic opening tools, pry the left bottom corner of the battery up.
    • Using the plastic opening tools, pry the left bottom corner of the battery up.
  4. Pull the battery up and out.
    • Pull the battery up and out.
  5. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  6. Remove the two Torx T5 screws.
    • Remove the two Torx T5 screws.
    • Remove the one Philips #00 screw.
  7. Using the plastic opening tool, pry up the battery housing upwards. Push pry tool down, undoing the plastic tab.
    • Using the plastic opening tool, pry up the battery housing upwards.
    • Push pry tool down, undoing the plastic tab.
  8. Pry the upper left tab open on the battery housing. Pry the upper left tab open on the battery housing.
    • Pry the upper left tab open on the battery housing.
  9. Pry the top tab of the battery housing. Pry the top tab of the battery housing.
    • Pry the top tab of the battery housing.
  10. Pry the right side tab of the battery housing. Pry the right side tab of the battery housing.
    • Pry the right side tab of the battery housing.
  11. Pull up on the battery housing. Slide the battery housing out to remove it.
    • Pull up on the battery housing.
    • Slide the battery housing out to remove it.
  12. Place the spudger under the metal cover and pry upwards. (shoot bottom side first with tabbed clip) Swap the spudger to the other side of the cover base. Pry upwards. (fix?) Grasp the camera module and pull up.
    • Place the spudger under the metal cover and pry upwards. (shoot bottom side first with tabbed clip)
    • Swap the spudger to the other side of the cover base. Pry upwards. (fix?)
    • Grasp the camera module and pull up.
Conclusión
Una persona más ha completado esta guía.
Niklas Johnson
Miembro Desde 31/01/12
1,063 Reputación
18 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 1
Todo El Tiempo: 3,371
