Introducción
installing the battery housing
  1. Using two fingers, push up on the rear cover.
    • Using two fingers, push up on the rear cover.
  2. The rear cover slides up and off.
    • The rear cover slides up and off.
    • Using the plastic opening tools, pry the left bottom corner of the battery up.
    • Pull the battery up and out.
    • Remove the two Torx T5 screws.
    • Remove the one Philips #00 screw.
    • Using the plastic opening tool, pry up the battery housing upwards.
    • Push pry tool down, undoing the plastic tab.
    • Pry the upper left tab open on the battery housing.
    • Pry the top tab of the battery housing.
    • Pry the right side tab of the battery housing.
    • Pull up on the battery housing.
    • Slide the battery housing out to remove it.
Conclusión
2 personas más completaron esta guía.
Niklas Johnson
Miembro Desde 31/01/12
1,063 Reputación
18 Guías creadas
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 1,467
